Coros Vertix Strap On Fenix 6 (anyone?)
Ok, shot in the dark here but does anyone here have a Coros Vertix that can try the QR strap from the Vertix and see if it fits on the F6 (22mm) spring bars?
I can tell you that the Vertix strap did NOT fit on the F5+ bar.
Thanks
  • I used Garmin fenix 5 straps on my Vertix. I'd assume they are cross compatible considering they're both 22mm quick release? What part didn't fit on the F5+?
  • The Vertix band does not fit on the F5+ due to the design of the quick fit system.
    I was hoping that the band would fit the F6 as I like the design of the Vertix band.
  • I have the COROS Vertix, Fenix 5 plus, and the Fenix 6 Sapphire. The Vertix quick fit band use smaller size pin which isn’t compatible with any of the Garmin Fenix 5 and up watches.
  • Thank you PaddyDeng.
  • Resurrecting this post instead of creating a new post.
    I bought a couple of the nylon with Velcro closure straps that Coros brought out with their Mojito model of the Vertix and will say that they work with the F6 and 945 with some qualifiers.
    Theres no quick fit type latch on these but more of a hook shaped press fit catch where you hook it over the pin at an angle toward the center of the watch and as you rotate it out to where it will be when worn it snaps into place.
    On the F6 the getting the initial placement right is a bit fidgety but once it snaps into place it’s a nice firm connection free of any interference with the case of the watch. Getting it off requires a pretty firm press, after rotating back toward the center of the watch, and pressing one one rather than across the whole catch works better.
    On the 945 the initial positioning is easier and so is getting it off. However on the 945 there is a slight interference with the watch case which gives it a bit of a ratcheting feel to swiveling the clasp.
    The band itself is quite comfortable. It’s a slightly elastic nylon and the Velcro holds well. I’m interested to see how it ages and if fitting it onto the watch gets a little easier after it’s been installed and removed a few more times.
  • could you please show some pictures from the closing mechanism on the watch with those straps ?
  • Is that Fenix 6 titanium? Interesting to know the total weight of the watch and the band.
  • would you pls try this band on FR 955 if you have it & share us the picture? Thanks
  • Ciao.
    Ma il perno del cinturino Coros non balla nel foro della cassa Garmin?
  • Not true. The Vertix strap fits an Instinct Solar just fine. It is tighter, but has worked flawless for me. It is 22mm.
