FW 19.41
I’ve had my Epix gen2 for about a month as an Apple Watch 5 replacement. I do a very similar PT session regularly, and I’m generally in tune with where I’m at HR wise.
A typical session might be 5-10% Z5, around 20% Z4, and a blend of the rest. The Apple Watch typically picked this up no problem. No tattoos, pale skin, wearing it plenty tight.
The Epix barely sees Z4, let alone Z5. I see intense exercise sat at 90bpm, and it dropping to 65 sometimes in the rest. I wore a strap today with the Epix, and saw my normal numbers as I’d expect. Wife does the same class sometimes, and sees sensible numbers on her venu2.
The Epix barely works as an exercise watch if the HRM doesn’t work. Are many others experiencing the same?
