Updated to 10.44 yesterday, now “screen always on” is turned off, and the button to turn it on again greyed out. Same for activities. It seems broken. Can’t turn it on with garmin connect either.
Thank you for your report. I am sorry there is an issue. Other than yourself and RIPCRL, there are no other reports worldwide that have come into Product Support. There may be an issue with only your two…
Thank you. It seems display was turned off. After turning it on again (as suggested in step 2) the issue was resolved.
nice !!
Same here, I am unable to get the screen back to "always on" and the gesture mode not activating the screen with out tapping the screen.
Thanks for info. I will stay to 10.43.
Thank you for your report. I am sorry there is an issue. Other than yourself and RIPCRL, there are no other reports worldwide that have come into Product Support. There may be an issue with only your two watches but the issue should be able to be resolved through troubleshooting further. I have tested for any AOD issues with my own Epix 2 on v10.44 software and I could not replicate the issue. My AOD is working properly along with the settings that impact it.
Please try the following:
- Double check your watch settings.
1) If your Power Manager > Battery Saver is On, your Always on Display is greyed out in your System > Display menu.
OR
2) If your Display is set to Off in your CTRL shortcut menu, (long hold your top left button) your Always On Display is grayed out in your System > Display menu
If your AOD continues to be greyed out and it was not your settings, try the following:
- Soft Reset your watch by holding down your top left button until your watch shuts off then let go of the button.
- Reset All Default Settings on your watch through the System > Reset menu.
Excellent. This solved the issue -thank you!
Same isseu with me.
Always On Display in Display during activity is grayed out and Wrist Gestrure is graded out as well at status Display Off
I DID NOT CHANGE anaything and until 2 days it worked.
I think there was a software update?
I have personally never seen a pattern of a software update changing the Epix 2 Display setting to off but as long as you are aware of both steps I gave above if you come across your option greyed out, you can quickly resolve it.
I've had the same symptoms..
than noticed that teh screen was locked.
release screen and thsi will be resolved
Sorry, resolved, It took me a whiel to notice that the screen was locked.
released screen and this was resolved
