Anyone experiencing the same issue or knows if its a bug? I was using a latest activity navigation course and the device kept on crashing.
I had similar issue. It happened consistently. I did some debugging and found the cause to be the “Heart Rate Chart” as “Data Field” in ClimbPro. Choosing a plain number, like “Heart Rate”, avoids the…
Yes. My Epix 2 restarts when using navigation and trying switch the screen (the next one after map is climb pro screen).
It looks like https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix…
Thanks for flagging this, I believe the bug might be *any* chart used in ClimbPro, I was using Pace Chart in ClimbPro and my Epix 2 crashed/restarted when my page turned past the map page. Hope Garmin…
What firmware version are you on? I think you need to give a little more details of you want people to help.
Its the latest version. when starting my MTB ride I selected to navigate and follow the last activity I saved. the minute I moved, the watch crashed and restarted. it happened each time I used the navigation, even when I chose a different rout.
Just happened to me today too, compass just stayed stuck in its position, navigation direction were screwed up, I plotted the corse but orientated me and the map the wrong way around.
I turned it off and on again a few times to get it working again, but it seemed really buggy all day.
Shame as the one hike previous worked perfectly.
Also on latest firmware
Firmware version: 7.24
I had a similar issue which also occurred only once in a day, point 3 here:
I had similar issue. It happened consistently. I did some debugging and found the cause to be the “Heart Rate Chart” as “Data Field” in ClimbPro. Choosing a plain number, like “Heart Rate”, avoids the crash. I’ve communicated the issue to Garmin support.
Thanks for flagging this, I believe the bug might be *any* chart used in ClimbPro, I was using Pace Chart in ClimbPro and my Epix 2 crashed/restarted when my page turned past the map page. Hope Garmin can fix this soon, but helpful to know a workaround.
Yes, same problem when navigation , the watch is freeze when select the routing and "Use Map" as well.
Thank you for this, was going insane trying to fix this!!! Still a problem in almost August 2024 with newest firmware!!!
