Durability of the screen?
I typically keep a watch at least the whole life cycle which for my 6x will be two years. Want to order the Epix but curious about the amoled screen. The sapphire glass will be good but what about that screen. Does it hold up over time?
  • My daughter still has a 4 year old AW3.  Not one issue with screen.   the OLED screens are extremely reliable.
  • Does it hold up over time?
    Ask me in a couple of years. Seriously though, nobody can answer how well the Epix2 screen will hold up over time. Individual use case will have some impact - Always on v Display off etc. I thought I might not take the plunge with either watch because of the touchscreen but the ability to control when it's on/off was sufficient to sway me.
  • First of all - the AW3 display is not always on. This reduces the risk of burn-ins significantly. Secondly, newer Apple Watches have a few tricks to minimize burn-in, for example the information being displayed is being "scaled down" when the screen goes into inactive state. This also helps a lot. Garmin does not have those tricks, and watches like the Venu have shown significant number of burn-ins after just a year. See for example forums.garmin.com/.../venu-screen-burn-in
    ** EDIT ** Garmin does indeed pixel scale/shift the display and lots of other tricks on the new EPIX.
    Moderator Edited to note: referring to the Epix 2 AMOLED, it automatically dims to avoid a burn-in issue.
  • Personally,on my Venu 2, i'm using Garmin's watchfaces as they have everything that i need on the AOD(live heart rate, hour, date, body battery and steps that i don't really need but they are there :D). I guess that Epix will have even more and more customizable watchfaces so i should be fine.
    Venu 2's AOD is also not always on...during sleep time it's completely off and the screen changes between the normal usage and the "stand by" mode + when you do activities or you check something it's changing.
    If that's not enough to prevent a screen burn-in then i expect to get a replacement from Garmin if it happens.
    I know that many(if not all of them) 3rd party watchfaces have a "burn-in prevention" option and i hope Garmin's too(if it's effective or not i don't know of course).
  • But as far as I understood, the user isn’t forced to use the aod the whole time and can disable the aod display:
    From the Epix manual:
    Changing the Screen Settings
    1. Hold MENU.
    2. Select System > Display.
    3. Select an option:
      • Select During Activity.
      • Select General Use.
      • Select During Sleep.
    4. Select an option:
      • Select Always On Display to keep the watch face data visible and turn down the background. This option impacts the battery and display life (About the AMOLED Display).
      • Select Brightness to set the brightness level of the screen.
      • Select Alerts to turn on the screen for alerts.
      • Select Wrist Gesture to turn on the screen by raising and turning your arm to look at your wrist.
      • Select Timeout to set the length of time before the screen turns off.”
  • Yes of course. It's a setting that you choose to select or not.
    You can keep it always off too or make it on with the wrist movement but AOD is a feature made by Garmin and if the screen get's damaged, because of their feature, i'm expecting a replacement as said before.
    I understand that it's my choice but i don't see anywhere a warning message about it usage.
    (just a random example) It's like if i use Spo2 measurment 24x7 and the sensor breaks...i'm getting in contact with Garmin and i should get another watch.
  • I would say, no guarantee no replacement.
    From the Epix manual, burn-in is -normal behavior- and I would read that as an -not under guarantee-.
    link to www8.garmin.com
    By default, the watch settings are optimized for battery life and performance (Tips for Maximizing the Battery Life).
    Image persistence, or pixel “burn-in,” is normal behavior for AMOLED devices. To extend the display life, you should avoid displaying static images at high brightness levels for long time periods. To minimize burn-in, the epixTm display turns off after the selected timeout (Changing the Screen Settings). You can turn your wrist toward your body, tap the touchscreen, or press a button to wake the device.
  • I understand your concern but i'm speaking from my personal experience with Venu and Venu 2 and i didn't/don't see any visible burn in after months of usage.
    I'm not doing anything special to prevent it...i have AOD all the time but there is a difference between "active AOD" and "stand-by AOD"....the brightness change and on Venu 2, and i guess on Epix too, the 2 watchfaces are also different with the second one having less details and maybe other tricks(pixel shifting or whatever they use) to avoid burn-ins. 3rd party watchfaces for the Venu had the option "prevent burn-in" that you were able to check or uncheck.
    After reading that statement in the manual i'm still going to risk with the Epix as it fits a lot more whit what i want from the smartwatch...if i get any visible burn-in i will contact Garmin and let you know how it goes.
    Few points to analyze a little bit:
    1)To extend the display life: what does this mean? To extend how much? From 5 years to 10 years? From 1 month to 2 years?
    2)you should avoid displaying static images at high brightness levels for long time periods: long time periods=? 1 minute? 5 Hours? 2 days?
    I don't think they are making a watch that costs a thousand of dollars with issues that can arise after few months.
  • When I buy a thousand dollar watch, I expect it to last at least 4-5 years. After using previous Garmin watches I don't see myself switching off AoD. So it's quite obvious witch Garmin's own info on AMOLED displays that Epix will eventually get a burn-in. It's just a matter of time. Thankfully there's still Fenix 7 :)
