Hi, how is it possible to watch the heart rate during a dive and in the dive log? I use the watch directly on the wrist when I wear a wet suit and an Hrm-pro when I use a dry suit.
Thank you in advance, Vito
You can only see live HR during a dive if you are only using your optical sensor. Your HRM strap can't communicate through water, even in a dry suit. You will still see your HRM readings for your recorded activity since your HRM-Pro will use the store and forward ability to provide your heart rate when you save the dive.
Thank you very much Chris, but I can't see this information in the Garmin dive app. Where can I find it?
If not seeing it, you will need to manually download the Heart Rate data and then it will show on your Garmin Connect account instead.
- How Does the Store and Forward Feature on My Heart Rate Strap Work?
Today ik tried it with the G1 and a Polar H10 strap. But what type of connection works better? Bluetooth or ANT+? I dive with a 5mm dry-suit in Holland. So will connect Bluetooth better of will connect ANT+ better while wearing the dry-suit?
Hi, using a garmin descent g1 can I read heart rate underwater?
Yes, you can read the HR from the wrist HR sensor underwater in real-time.
If you use a HRM strap, you need one supporting the feature Store & Forward (i.e. HRM-Pro), because the transmission does not work underwater, regardless whether you use a dry suite or not. HRMs with the Store & Forward functionality transfer the data to the watch after the dive.
