Hi, my Garmin Instinct won't turn on. It stay on garmin logo, i try to do the master reset and soft reset but don't work. Somebody could fix this issue?
You can try also this. Not sure whether it helps, but trying it won't harm anything:
(source)
If you can access the watch folders through the USB cable, check also the activities folder, if it is not overfilled with files. The reason of the frozen state could be perhaps due to full storage. You can delete older activites to free up some space.
Thanks for the answer. Last night i did all the steps you are describing and this morning was alive, but every time i turn off the problem is repeated and need at least 2 hours to respond. I'm going to try connecting to the computer and remove activities.
I am sorry your Instinct is not powering on. Please use this Support Center article to see if you can get it to come back around and power on or charge again:
- Will Not Power On (Review the Will Not Power on section.)
I am facing the same problem with my Garmin Instict Solar 2.. it freezes on the garmin logo and stays there forever.. tried powering it off and on for a number of times already.. problem persists.. How do I determine if this is a firmware issue or a hardware issue?.. 0.o
Were you able to resolve this? I just did 30 mins on an elliptical and when I *** save it just switched off and is completely unresponsive.
@Aditya
I am sorry there is an issue. You might be able to get your watch to respond again.
Please follow the steps in this Support Center article under the Will Not Power on Section.
Please note: the site given is not an official Garmin site.
I fixed this by connecting my charger for a while. I then connected it to a computer and deleted any saved activities / GPS points. Then I did a hard master reset and fully charged it. Seems to work fine for now.
