Fenix 5X - 8.54 Public Beta
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures!
Fenix 5X: http://www8.garmin.com/support/downl...s.jsp?id=11665
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
8.54 Change Log Notes:
  • Added the Kayak app.
  • Added support for Connect IQ SDK v2.4.2.
  • Added the ability to save Stopwatch recording as an activity. Go to the Stopwatch control, and start the timer. Stop the timer, and select Done. You can then save your activity, which will appear in your History.
  • Enabled the Auto Set setting for Strength activities. To access this setting, go to your Strength Settings, and select Auto Set. When enabled, sets automatically advance during free Strength activities.
  • Enabled the Edit Weight setting for Strength and Cardio activities. To access this setting, go to your Strength or Cardio settings, and select Edit Weight. This setting will control whether or not you can edit the weight when editing sets.)
  • Fixed an issue causing an incorrect time to be displayed.
  • Fixed an issue preventing time zones with Arabic characters from being displayed in the Time Zone widget.
  • Fixed a potential crash when using Group LiveTrack.
  • Fixed an issue resulting in high cadence and calorie values when using some power meters.
  • Fixed an issue preventing Rep Counting activities from advancing correctly when the Lap key is disabled.
  • Fixed a potential issue causing the 'Wheel Size Computed' notification to appear frequently.
  • Fixed an issue causing the Elevation graph to not update frequently.
  • Fixed an issue causing some workout prompts from a Training Calendar to be repeated after completing the workout.
  • Fixed an issue where the grade data field was displaying incorrect data.
  • Fixed an issue where GPX files with a certain data format could not be parsed by the device and would display a blank map.
  • Fixed an issue with calendars details page where the title and location information were not displaying properly.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
Please note, the beta updates released on these forums are not suitable for APAC region devices.
  • Clearly not everyone thinks it is "crap firmware." As I mentioned, your experience doesn't match mine with this beta firmware version. My only complaint is the somewhat higher battery use.
    This firmware is below crap, even a blind dude can see it. It was coded by a monkey and most likely a drunken one. Please garmin buy my watch back, maybe the software was writing in the indus.
    More interesting fact - I can see on the main Dashboard of Garmin Connect - my current Pulse (it's dynamically changing), Goals - but Sync. doesn't operate correctly.
    See a screenshot - https://www.dropbox.com/s/u5rsbt3iaegvv5p/Fenix5x-failed-sync-but-Pulse-is-working.png?dl=0
    After 1-2 mins synchronization, it was stopped, but Pulse value was still working. It's very strange. Messages from phone were not accepted.
    More interesting - I've got incoming call notification on my Fenix 5x (Beta 8.54) - vibration, text - But synchronization was started 3-5 times and was dropped at the end. So, in this case, I was able to connect my F5X with help of USB cable. :-( Hey, Garmin guys! Are you going to comment this situation?
  • [h=1]Navigating to Your Starting Point During an Activity[/h]
    Might not be an 8.54beta problem, Tried to navigate back to my starting point on a 10k run (route back not track back) and it gave me an error of not enough memory. Anyone had the same?
  • This firmware is below crap, even a blind dude can see it. It was coded by a monkey and most likely a drunken one. Please garmin buy my watch back, maybe the software was writing in the indus.
    You expect perfect software from a drunken monkey... Move on. Get yourself some other watch. ;-)
    If I were Garmin I would already removed you from the boards because of your choice of words...
    Yes, and just to add to your frustration: My Fenix 5X works as a charm. And I am using the latest beta.
  • I also notice a big battery drain in 8.54 compared to 8.0
    The two first loading cycles are with 8.0 the 3rd and 4th with 8.54. Training load was about the same. Maybe a bit less in towards the end of the chart.
    Works as a charm????
    Now I see what the definition of charm is in your dictionary. ;-)
    Hello there Mr. dude, I do except a good working software for a hardware that it is expensive, my most sincere apologies if that is asking too much. Most likely for the way you are writing you seems to be a “do gooder with a soft and thin skin”. Mr. dude thanks so much for telling me to get another watch I am trying to do so as well, but Garmin is not buying mine back, I even send them emails asking them to buy it back, they aren’t doing it, maybe they will listen to you, especially with such a good relationship you guys seem to have, because if your watch works like a charm you must have good friends at Garmin and running a different software than most of us around here., maybe a different kind of beta.
    I am not frustrated; I am just having fun back at a company that lied to me.
  • you expect perfect software from a drunken monkey... Move on. Get yourself some other watch. ;-)
    if i were garmin i would already removed you from the boards because of your choice of words...
    Yes, and just to add to your frustration: My fenix 5x works as a charm. And i am using the latest beta.
    lol!
    The day before yesterday I found a headband I had been looking for for 2 months... and it was on the box of that supposed marvel of technology I was sold for 750€ about a year ago by Garmin.
    I assumed it was a divine sign and immediately charged the watch. This is the result, screenshotted by cell phone (no mistake on the date then).
    https://imgur.com/OSkPKCC
    Nothing wrong with the altimeter, according to tech support and Garmin will soon answer about this in a Court of Law.
    https://imgur.com/zDLhQcK
    35 posts in 5 years... of course his watch works like a charm. :rolleyes:
    Hourly notifications were frozen on display until I pressed Start button once more. In this case Watchface or Activity proceed to work. But function auto-close for notification didn't work for me.
    P.S. Just for info - I didn't install new watchfaces, dataf-ields and applications.
    P.S. 2 - In my situation, this is the worst beta firmware (8.54) I installed. So much troubles have come for one upgrade. :-((
    I have contacted to [EMAIL="[email protected]"][email protected][/EMAIL] with a proposal to help. Ready to show, give datas, photos - to correct errors or investigate the problem - none of the developers even contacted me. :confused:
