Fenix 5X - 8.54 Public Beta
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures!
Fenix 5X: http://www8.garmin.com/support/downl...s.jsp?id=11665
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
8.54 Change Log Notes:
  • Added the Kayak app.
  • Added support for Connect IQ SDK v2.4.2.
  • Added the ability to save Stopwatch recording as an activity. Go to the Stopwatch control, and start the timer. Stop the timer, and select Done. You can then save your activity, which will appear in your History.
  • Enabled the Auto Set setting for Strength activities. To access this setting, go to your Strength Settings, and select Auto Set. When enabled, sets automatically advance during free Strength activities.
  • Enabled the Edit Weight setting for Strength and Cardio activities. To access this setting, go to your Strength or Cardio settings, and select Edit Weight. This setting will control whether or not you can edit the weight when editing sets.)
  • Fixed an issue causing an incorrect time to be displayed.
  • Fixed an issue preventing time zones with Arabic characters from being displayed in the Time Zone widget.
  • Fixed a potential crash when using Group LiveTrack.
  • Fixed an issue resulting in high cadence and calorie values when using some power meters.
  • Fixed an issue preventing Rep Counting activities from advancing correctly when the Lap key is disabled.
  • Fixed a potential issue causing the 'Wheel Size Computed' notification to appear frequently.
  • Fixed an issue causing the Elevation graph to not update frequently.
  • Fixed an issue causing some workout prompts from a Training Calendar to be repeated after completing the workout.
  • Fixed an issue where the grade data field was displaying incorrect data.
  • Fixed an issue where GPX files with a certain data format could not be parsed by the device and would display a blank map.
  • Fixed an issue with calendars details page where the title and location information were not displaying properly.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
Please note, the beta updates released on these forums are not suitable for APAC region devices.
