Weather does not show correct temp, sometimes is correct but mostly off if at all. Sync with app and still wrong temp
Please sync your Approach S40 through the Golf APP and see if your weather shows more accurately again. If you have the Connect Mobile APP installed too, please manually sync in the GCM APP too.
For all…
- Thank you for the update!
Everyone that is following this thread, please test keeping your Garmin Connect Mobile APP open in the background on your Android smartphone to see if that resolves your Approach…
at times the weather is still not correct. don't think the garmin app is running in the background all the time. if i sync the app then the weather will be correct
I see the same issue on the S40 an S42
Please add me to the list.
I am sending you a private message to gather additional details.
My s40 will work if I set garmin connect weather to "set location ', but it shows Afghanistan if I set it to use my phone location. I live in Wisconsin. I guess that works, but if I'd rather know the temperature in my location.
Weather info on my new S40 is way off even while running Connect . What is being done to correct this?
I have same issue, anyone how solved this issue?
Chris, I still have the issue with garmin S40 showing weather that is not my location. 112 in my location and watch shows 70. Please advice when fix available
Same. Has Garmin given up on this? It really doesn't seem like a difficult issue to fix. What can we do to help resolve this?
I have reached out to Golf engineering to see if I can learn more on why the issue has not been resolved yet. I will update once I have received a response. My sincere apologies to all of you. You have all been incredibly patient. Thank you.
Golf engineering got back to me and stated that the cause of the issue continues to be worked on. Once the issue is resolved, all customers that have been added to the tracking case will be emailed by our Outdoor Helpdesk team.
I am sorry we do not have an estimated time of completion. Meanwhile, the workaround will be to use the weather widget on your smartphone.
Mine still isn't working. I've turned it off. I traded my s20 for the s40. S20 worked great. Not impressrd with the s40!
