Weather does not show correct temp, sometimes is correct but mostly off if at all. Sync with app and still wrong temp
Please sync your Approach S40 through the Golf APP and see if your weather shows more accurately again. If you have the Connect Mobile APP installed too, please manually sync in the GCM APP too.
For all…
- Thank you for the update!
Everyone that is following this thread, please test keeping your Garmin Connect Mobile APP open in the background on your Android smartphone to see if that resolves your Approach…
at times the weather is still not correct. don't think the garmin app is running in the background all the time. if i sync the app then the weather will be correct
Well that didn't last long.
Connect running in background and temp is way off, if what it says was actual temp I'd be playing golf
Have sync app numerous times
One thing on my end......with the connect app staying open in the background I also have the weather location pull from my phone location and not a fixed location under user settings. this may help if you're having issues.
I've tried keeping the app on and setting manual location, but the weather is very wrong.... It says 90 degrees, and I'm looking out the window at snow, haha. It's wrong even immediately after sync with either the golf app or the connect app. It doesn't seem to ever be correctly updated.
I just noticed that the Connect app keeps resetting the weather location to "phone location" instead of "fixed location" after I set it. I don't allow Connect to use the GPS, so this may be the issue.
Thank you for the information. For anyone that continues to receive the wrong weather information despite syncing through the Golf APP, please highlight my name and send me a Private Message if you are willing to provide further information our engineers are still needing to track down the source of the issue. Thank you!
The bug causing the weather to improperly show 80/80 is not resolved. I saw your direct private message. I will respond to you to get you added to the main report sent to our engineers. Our Outdoor Helpdesk team will email you once the issue has been resolved.
For any other Approach S40 owners that see this thread experiencing the weather issue, please highlight my name and send me a Private Message if you are willing to provide further information our engineers are still needing to track down the source of the issue. Thank you!
When I looked at my Android notifications control panel "Weather" was turned off. Turning it on and resyncing fixed it. I'm using an S62 and Android 11
My s42 is not showing correct weather. I've tried both phone location and fixed location. Syncing, turning off/on, syncing more. Nothing works. Please add me to the list to be notified. I have now turned off the weather widget.
This thread is for the Approach S40 model, however I would like to investigate the issue you are having with your S42. I am sending you a private message.
