GPS about 30m off
I have noticed this twice now. After using my GPSmap 67i for a few hours the gps is at once way off.
We went for a little walk this evening to find a cache. The gps worked fine until the last waypoint. We were on the right spot and according to the gps we were 30m away from that waypoint.
In the hurry of that moment I didn't notice the fault right away, but being home in my backyard I see the gps is still way off.
Multi-GNSS is selected and Multi-Band is on. According to the Satellite page  there could be a variation of 1.8m. On the map I can see the gps is at least 30m off.
Switching the device off and on solves it directly. I had the same experience yesterday (not caching or walking at that time, just playing with this new toy at home), so it is not just a one time glitch.
I wonder if someone else has this experience as well and I hope someone can tell me I can solve this behavior by myself.
Regards,
   Edwin.
  • You are to quick with your response JungleJim, I hadn't finished JoyWink
    Yes, I took the data from the .FIT files. I wrote software to derive the data from the .FIT files with cm accuracy.
    I converted WGS84 coordinates to the Dutch Map Datum (RDNew), which expresses the coordinate as Northing and Easting, in meter. I believe this is more accurate than calculating distances using Haversine, since the Dutch Map Datum is especially for Dutch territory. It also made calculation easier (pythagoras...). All in Matlab Relieved
    RINEX is on my bucketlist. I need some conversion software that derives coordinates from the raw satellite distances. RTKLib requires an academic degree it seems...
  • Great, you seem to know your stuff Slight smile
    RINEX data analysis would indeed be interesting. Early firmware versions of the GPSMAP 67 produced RINEX data that was simply incorrect (missing bands, duplicated data to name a few). Garmin fixed it eventually, so it would be interesting to see if the data is actually correct and useful.
    Hopefully Garmin engineers can do something with the info in your blog post.
    PS. Groetjes vanuit Nederland Slight smile
  • I’m getting 110 meter or more drift too.  Do you know if Garmin is working on a fix?  It’s definitely not normal.  Did anyone get a replacement and have the problem fixed?  It would be helpful if the Garmin engineer(s) explained the problem and people could decide for themselves if it’s worth the risk to have that much error in an SOS device with both L1 and L5 enabled.  Oh the irony.
  • I submitted the error to Garmin Support in the Netherlands (NL) and provided all kind of proof. They indicated it is 'by design'. Then I turned to Garmin Support in the US. They were aware of my submission to Garmin Support NL. They don't see it as an error. But in the end they offered me a replacement, which I did not take (because I don't believe this solves the problem and you get a repaired one).
    I took the GPSMAP 67 and Fenix 7 to Madeira on a number of hikes mountainous area. On a number of to and fro hikes I counted the times it deviates more than 10 m. The GPSMAP 67 performs worse than the Fenix 7. See my blog, at the end of the page.
    Apparently when the going gets tough, this tough doesn't get going...
    I sold my device on the second hand market, highly disappointed.
  • Thanks for the reply and testing. One of the things it appears they’ve done is altered the gain on L5. L5 is supposed to have twice the power as L1, but they’ve tinkered with it (I assume to save battery).  I just wish they’d tell customers that.  You’re probably right about the sensor fusion algorithm being messed up.  I can’t help but wonder if the Garmin software engineers know that the Department of Defense has GPS L5 marked as unhealthy and they have to manually override that in the firmware.  I’m going to give a couple more days before I decide whether or not to return it.
  • I know this is an old post, but I wanted to add that a year later, with the 67i, that I see similar errors. I'm using the unit in Yuma, Az. returning to the same sampling points in Nov 2024 and Jun 2025. We are planning to return to the same points in Jun 2026. So I will be curious, what results I get when compared to the mapped point (ArcGIS Pro) and a new Bad Elf Flex GPS unit.
