R 10 isn’t on the list of compatible monitors
As of September 19th, 2023:
This would also involve GSPro, and not only Garmin...as we cannot simply make something compatibility from just our side.
We are still monitoring reports of users wanting compatibility…
Response regarding R10 updates provided to your comment on post: https://forums.garmin.com/outdoor-recreation/golf/f/approach-r10/336785/no-more-updates/1784372#1784372
Updates to the Approach R10 have…
GSPro is currently is not officially offered as a compatible platform for use with the Approach R10.
We are currently looking further into users wanting support for the Approach R10 and GSPro as a compatible…
Why when it works well without?
Hey, how do you calibrate R10 while BT connected to your PC? I BT connect my phone as well with app and then calibrate but then github app won't connect unless I disable BT on my phone, can you calibrate off PC? How do you do it?
Hi. The bluetooth connector will calibrate the unit automatically when You start it. It should also wake up the unit if it falls asleep. So all You have to do is focus on Your golf
I have a Garmin R10 and was hoping I could interface the GS Pro to my IPAD and then connect to my bluetooth/WiFi 4k projector wirelessly. Is this at all possible?
GS Pro only runs on Windows. Howver it is possible to connect the r10 to GS Pro. On YouTube look up (external link removed) and search for his videos on this topic.
External link removed per Terms of Use.
I would really like to see GS pro added to the Garman R10.
so that I understand it correctly, which GsPro bundle do I buy for the Garmin R10, I assume the last one in the selection list " Other (OpenAPI) is this correct?
thanks a lot for your fast answer :-)
ok now i can buy the correct Bundle, and now i need the correct File to connect the Garmin R10 with the Windows PC directly, my information is to check the video from Joe Lagowski.
I ask GSPro what's happend when i buy after months or years a new supported launch monitor.
Answe GsPror: You can use our easy, and free, conversion tool here! (external link removed)
I hope that the rumors are true and garmin brings the R50 to the market and that you can then officially connect it to GsPro if not then just like the R10 now :-)
I am not a computer genius but if there is a link to a manual Windows Firewall etc. Step by step (PDF) etc. that would be great.
GSPro + Garmin R10
thank you very much again
Hi. I strongly recommend to use discord for GSPro questions. Sgt (simulator golf tour) has dedicated channel for R10, and way more active than here. There You will also get help on connecting Your R10 to GSPro, putting etc.
