Ticket Created
WERETECH-11176
Transferred
Wifi audio syncing does not work properly on Venu and maybe others
Hello,
I've developed and audio book app that downloads a series of mp3 files from a server.  I've been running into a frustrating problem where Communications.makeWebRequest fails on Venu hardware after about 3 files download (around 40MB) or any single file larger than 40MB.  I'm not sure if something eventually times out on the watch or what.  The simulator pulls the files with no problem at all.
I have the watch less than 1 meter from my Wifi router.  I only have a Venu to test this with, but I've create a repo with my test code and my binary for reproduction.
It just needs to be built and run on the hardware.  The sync should fail pretty much 100% of the time.
https://github.com/primetime00/garminWifiTest
I believe this issue is also what is causing poor sync performance for Spotify as well.
Thank you
SW: 5.80
GPS: 4.80
ANT/BLE/BT: 6.11
WiFi: 2.60
TSC: 2.10
Sensor: 8.02
WHR: 1.00.06
ConnectIQ: 3.2.5
BMX: 1.0.6
Secondary BMX: 0.8.0
