I am implementing a confirmation dialog on exit, so capturing the escape key like this:
case Ui.KEY_ESC:
var dialog = new Ui.Confirmation("Are you sure you want to exit?");
Ui.pushView(
dialog,
new AppExitConfirmationDelegate(),
Ui.SLIDE_IMMEDIATE);
return true;
break;
Using this confirmation delegate:
class AppExitConfirmationDelegate extends Ui.ConfirmationDelegate {
function onResponse(response) {
if (response == Ui.CONFIRM_YES) {
// If user confirmed, proceed with exit
Ui.popView(Ui.SLIDE_IMMEDIATE);
It works in the simulator on all devices.
It works on some devices I have (e.g. 830 is fine) but on the edge 540 when i click the escape button to "CONFIRM_NO" the program exits anyway.
I believe this is a bug.
