Acknowledged
VS Code: cannot rename project subfolder
- Windows 11
- SDK 8.1.0
- Monkey C extension 1.1.1
Use case:
- I want to make a copy of an existing folder (e.g. "resources/" => "resources copy/") and rename it (e.g. to "resources-spa/")
Recreation procedure:
- Open existing project in VS Code
- Copy/paste resources/ in place (CTRL-C, CTRL-V). This will create a copy called "resources copy"
- Rename "resources copy" to "resources-spa". The rename action will spin forever in VS Code - it may or may not complete if you close the VS Code window. (After you close the VS Code window, you can rename the folder by other means, such as using File Explorer or Terminal)
I suspect the Monkey C extension's language server is locking all of the project folders.
