Acknowledged
CIQQA-3097
Vivoactive6 simulator: menu key not working
In the simulator for the new Vivoactive6, the menu key (m) is not working.
Also the image only shows a black and white scheme of the watch, but maybe that's intended?
Parents
  • At first glance this seems like a super radical change: Vivoactive 6 is literally the first Garmin watch which doesn't have a universal "menu" button / gesture.
    Every other Garmin watch has some sort of universal (or near-universal) gesture to open a context-sensitive menu:
    - dedicated physical (or capacitive touch) menu button
    - "menu button gesture" corresponding to long press of a certain button (like UP on 5-button watches). (But even on 5-button watches, in *some* cases, long press of UP does something else, like panning/zooming the map faster than normal)
    - long-press screen to open menu (Vivoactive 3, as it only has 1 button)
    But I know runners who've worn a Garmin for years and are completely unaware that holding UP is supposed to open a context-sensitive menu / settings menu. Obviously there's nothing intuitive about the previous system.
    Obviously Garmin noticed this a long time ago, which is why they changed the activity start page so you can just short-press UP to open the menu (and there's an accompanying button hint). Fenix 8 took this further and allowed you to swipe for settings on the activity start page.
    Apparently, Vivoactive 6 is taking this even further by ditching the universal menu gesture, and instead showing an on-screen interactive hint (action menu indicator) for *all* context-sensitive menus, which can only be activated by touch.
    Ofc 5-button watches which support touch will probably still need a dedicated menu button/gesture, as they're meant to have full (or nearly full) functionality when touch is disabled. But I wonder if the action menu indicator (or something like it) will eventually appear on all Garmin devices.
    It seems that any app which implements a context-sensitive menu will be required to use the action menu indicator, as there's no longer a generic way to open a menu by pressing (or long pressing) a physical button
    To expand on this, I assume that any app which wants to display a context-sensitive full-screen menu (such as a settings menu) will be "required" to first provide the user with an action menu; the action menu can have an item which opens the full-screen menu (like "Settings").
    Or it could also work the way DCR described accessing watch settings, where settings is just another item in the activity/app list. ofc that only works if you're already displaying some kind of menu or list in the first place.
Comment
Children
No Data
