Acknowledged
CIQQA-3123
Vivoactive 6 Simulator problems
The Vivoactive 6 simulator does not seem to respond to a Menu command, and only responds to the buttons in a very tiny area along the edge of the button where it meets the body of the watch in the simulator.
The Vivoactive 5 simulator operates as expected so it looks to me like this is a set of simulator bugs.
  • > On a real va6, some of the system menus pushed usnig the menu indicator are full screen menus so this does not look out of place.
    Thanks for mentioning this.
    I take back what I said earlier, in that case. (I wrongly guessed that the real va6 would never push a fullscreen menu using the action menu indicator.)
  • This is exactly what I am doing, except I use an input delegate so am catching the KEY_ACTION_MENU, but I simply push my Menu2 rather than using an actual action menu.
  • Since all I want to do is get to the same menu I use on all other devices it seems the most minimal way of adding support is just the following:
    //In my main View initialize() turn on Action Menu indicator
    if(View has :setActionMenuIndicator) {
       View.setActionMenuIndicator({:enabled=>true});
    //In my view delegate catch the action menu invocation and just create my regular/legacy menu
    function onActionMenu() {
      return onMenu();
    This seems to work fine in the simulator.  Anything I'm not considering with this?  Not seeing a need to use the ActionMenu, ActionMenuItem, ActionMenuDelegate for this.
  • > Therefore, based on presence of View.setActionMenuIndicator I will use ActiveMenu to build my main menu, otherwise I will continue to use Menu or Menu2.
    That is the expectation
  • > So as developers I wonder if we are safe to assume we will see EITHER legacy onMenu() (non-touch or mostly button devices) and onActionMenu() (touch or mostly touch devices). Therefore, based on presence of View.setActionMenuIndicator I will use ActiveMenu to build my main menu, otherwise I will continue to use Menu or Menu2.
    I think that could work.
    You could also check simulator.json to see if onMenu is mentioned in the keys[] or display.behaviors[] arrays.
