Ticket Created
WERETECH-9013
Vivoactive 4S swipe identified as a key pressed
At least on the Vivoactive 4S, since I wasn't able to test this out on other devices, there seems to be an undocumented / unwanted behavior that is not directly visible when testing in the emulator.
While developing Monky (https://github.com/vladmunteanu/monky), I had to adjust one of the minigames so that it checks for a key pressed event instead of a swipe right, because when the app ran on the actual watch, it would trigger the onKey event, instead of onSwipe. (https://github.com/vladmunteanu/monky/blob/37fae93329cd7875d9d3c05c9a64c6cffd4cee07/source/SwipeGame/SwipeGameDelegate.mc#L17)
If intended, the documentation should at least be changed to reflect this when implementing an InputDelegate.
Parents
  • Yes, this is happening on production firmware for the FR965 and Epix (Gen 2). In the case of the Epix, this happens on latest stable and on latest beta on actual devices (it's fine in the simulator).
    I can create a new bug report, if you'd like. But, that said, it's incredibly frustrating as it is so hard to know if a new bug report should be created or not, without any visibility into the status of fixes. From my perspective, this bug seems to still be open with no fixes or follow up reported here and the problem I have run into is the exact same as what reported; specifically (and only) the left-to-right swipe.
Comment
Children
No Data
