Ticket Created
CIQQA-925
Venu2 - pictures in full palette buffered bitmap not showing up
  • Hi together,
I have response from users with the new Venu2 Plus.
Some elements are missing on my watchface. I cant reproduce this with simulator. The issue causes on a Venu2 and PLUS with new bufferedBitmap API.
I find out, that all pictures (jpg's and png's) are missing, witch I have draw on a full palette buffered bitmap.
The buffered bitmap is created with the new API:
		PictureBuffer = Gfx.createBufferedBitmap({
        	:width=> VA_Width,
            :height=>VA_Height
		PictureBuffer = PictureBuffer.get();
		PictureDc = PictureBuffer.getDc();
the pictures are draw in the buffered bitmap:
BackgroundPicture = Ui.loadResource(Rez.Drawables.EarthNight)
PictureDC.drawBitmap(73, 50, BackgroundPicture);
I draw the buffered bitmap later to dc:
dc.drawBitmap(0, 0, PictureBuffer);
All other elements from the buffered bitmap are shows correct, only the pictures are missing.
Have anybody the same problem on a Venu2 series?
It seems a firmware bug?
best regards
2aCD
  • I am having the same issue with the fenix 6, where the buffered bitmaps is showing on the sim but not on the real watch
  • Hi together,
    I have found a workaround for this issue.
    Please set the new additional property for createBufferedBitmap:
    :alphaBlending=>Gfx.ALPHA_BLENDING_PARTIAL
    Then all loaded pictures shows correct on a physical device.
    Very strange and I think it’s a firmware issue.
  • It seems now also nested bufferedBitmaps run in the same issue.
    I have draw Minute marks in a buffered bitmap with palette and draw later this bitmap  in a full color bufferedBitmap.
    At last the full color bufferedBitmap is draw to dc. Then the hash marks missing on a real device. In simulator all is showing correct.
    This is now a major problem. What is here going wrong with the new bufferedBitmap api.
    Please can give anyone here a response?
  • I have now a response from a Venu2 user with the same issue. But not all Venu2(plus) users have this problem.
    Is it possible that’s the user have another general settings on the watch?
