Acknowledged
venu 2 - less time until watchdog fires?
On the venu 2 I have a report on Data Lover where the code fails due to "'Watchdog Tripped Error - Code Executed Too Long'' while iterating over the hr values to chart the "Line Chart - Hr". This is not an issue on other devices. Is the time on a venu2 before the watchdog fires maybe less than on other devices?
Error: 'Watchdog Tripped Error - Code Executed Too Long'
Details: 'Failed invoking <symbol>'
Time: 2023-01-15T09:20:58Z
Part-Number: 006-B3703-00
Firmware-Version: '11.16'
Language-Code: fre
ConnectIQ-Version: 4.1.5
Store-Id: bcb58298-3e71-4d9a-9084-169e581df99c
Store-Version: 111
Filename: CCQB2224
Appname: Data Lover
Stack:
- pc: 0x10005fe6
- pc: 0x10009066
- pc: 0x10004e0b
- pc: 0x10008f4c
Parents
  • @Anshul.ConnectIQ I saw later on that it's due to the fact that the historization is longer on the venu device (eg 2880 samples for heart rate). I can work around it by limiting the scope of the loop. The question raises though if you have the possibility of the longer history should you then also not be able to browse the full history of that  type within 1 watch dog cycle. I think you ought to be able.
Comment
Children
No Data
