Ticket Created
WERETECH-10768
venu sq trouble with BufferedBitmap
according to problems describes in
https://forums.garmin.com/developer/connect-iq/f/discussion/253187/venu-and-venu-sq-differences
I think that venu sq doesn't support BufferedBitmap.
The strange is that I was sure I posted this bug erly but can find it (maybe still problems with forums)
  • but still for same regions even 2.50, 2.60 work bad
    Error Name: Symbol Not Found Error
    Occurrences: 179
    First Occurrence: 2021-04-25
    Last Occurrence: 2021-04-30
    Devices:
        Venu® Sq: 2.60, 2.40
        Venu® Sq. Music Edition: 2.50, 2.60
    App Versions: 1.10.0
    Languages: chs, eng, ind, jpn, kor, tha, vie
  • Users have confirmed that after update watch to ver. 2.5  there is no problem with BufferedBitmap. :)
  • Yes it support because I can create but not run as on all other types of devices.
    I think that is a problem with colours/palette, Everything was described in https://forums.garmin.com/developer/connect-iq/f/discussion/253187/venu-and-venu-sq-differences
    but I repeat
    - error is Error Name: Symbol Not Found Error when I call setColour...
    - I have 12 controls where 8 are based on buffered bitmaps and all produce errors:
    - I don't have venu sq tests was done by user
    - when I made deep tests using ciq api watch reset and it ended test
    pseudo code:
    //globals
    gDC = GRA.COLOR_DK_GRAY;
    gBC = GRA.COLOR_BLACK;
    const P_NUM		= 8;
    var PAL_COL =
    	0x00AAFF,//00
    	0x00FF00,//01
    	0x55FF00,//02
    	0xAAFF00,//03
    	0xFFAA00,//04
    	0xFF5500,//05
    	0xFF0000,//06
    	0xFF00AA //07
    //class functions
    function mBuff()
        var palette = new [P_NUM + 2];
        palette[0] = gBC;
        palette[1] = gDC;
        for(var i=0; i<P_NUM; i++)
        	palette[i+2] = PAL_COL[i];
        mBuf = null;
        mBuf = new GRA.BufferedBitmap(
        	:width => mWbmp + mFrameThickness,
        	:height => mHbmp + mFrameThickness,
        	:palette => palette
    function draw(dc)
        mBuff();
        //obtaining dc
        var d = mBuf.getDc();
        d.setColor(gBC, gBC);
        d.clear();
        //drawing
        drawP(d,....);
        dc.drawBitmap(mBpmX, mBmpY, mBuf);
    //function drawP(dc,....)
      dc.setColor(mPalCol, gBC);//ERROR
  • Hi, we could use a little bit more information. The Venu sq is intended to support BufferedBitmaps. There were some changes for newer 4.0 SDK devices, but the Venu sq is not one of those.
    Which SDK version are you using and would you be able to share the part of your code that you believe is causing an issue?
  • There is new hw https://forums.garmin.com/sports-fitness/healthandwellness/f/venu-sq/256971/venu-sq-and-venu-sq-music-software-updates---2-50
    Is maybe something in new version connected with my issue?
    If Garmin makes fix is any feedback about it? I removed compatibility for venu sq and I don't know when I can put it again.
