Acknowledged
Users complain of very small text in simple data fields
Original thread: https://forums.garmin.com/developer/connect-iq/f/discussion/259355/users-complain-of-very-small-text-in-simple-data-fields
Although I can't personally recreate this problem, I am reposting it here for visibility, as multiple users have complained of this issue, for multiple simple data field apps.
Text of original post:
Is this happening to anyone else? At first it was only happening for one of my simple data field apps, so I thought it was an isolated incident.
Now a user of a 2nd simple data field app has made the same complaint. Some users report that they used to see normal-sized text, and one day it suddenly became small. More recently, some new users say that it's always been small.
In one case I'm only displaying characters available in number fonts (for simple data fields *) such as digits, ".", ":", and "-" (verified in the simulator). (* I'm aware that simple data fields may be slightly more restrictive than necessary when it comes to which characters it will display in numerical fonts. i.e. The set of available characters for number fonts may be bigger in some cases than the set of characters that a simple data field will render in a number font). Even in this case, I've asked an affected user to change the settings so that only digits are displayed, and the problem persists.
In the other case I'm only displaying digits.
And I can't recreate this in the simulator or on my real 935 device.
What I see on my watch (normal-sized text):
https://ibb.co/1QC0c5V
What they see on their watch (text that's too small):
https://ibb.co/sFCYvvY
It's not limited to one device as Vivoactive 4 and Edge 530 users have both complained.
The two apps in question are:
https://apps.garmin.com/en-US/apps/fd690281-9c22-4fee-a81e-3b7f39aa67c5
https://apps.garmin.com/en-US/apps/2bc8b0c1-dd83-4679-96f1-0ae2a0925920
The latter (Total Ascent) literally does nothing but convert ActivityInfo.totalAscent to the user's preferred units and round it to a whole number.
using Toybox.WatchUi;
class totalAscentView extends WatchUi.SimpleDataField {
	var elevationUnits;
	function getUnits()
		var settings = System.getDeviceSettings();
		elevationUnits = settings.elevationUnits;
	// m to feet
	private function convertAltitude(value)
		if (value == null)
			return null;
		if (elevationUnits == System.UNIT_STATUTE)
			value = value / 0.3048;
		return value;
    function initialize() {
        SimpleDataField.initialize();
        label = "Ascent";
    function compute(info) {
    	getUnits();
        var val = convertAltitude(info.totalAscent);
        if (val == null)
        	return 0;
        return Math.round(val).toNumber();
Parents
  • A more comprehensive workaround would be to implement a complex data field instead, but that's a bit more work and may not be feasible for data fields which need to support old devices, since there may not be enough memory for the additional code.
    And even current devices like Vivoactive 4 (released 2020) only have 32 KB for data fields, which is the same as the 6 year-old Vivoactive HR, so it's not just a problem for old devices.
Comment
Children
No Data
