Ticket Created
WERETECH-9125
Use of nested classes in Monkey C
I am trying to set up a data structure of an ANT device, and would like to use a sytem of nested classes for the data structure, so for example you would have a sensor data object, with a "page 20" property, which itself has "event count", "temperature" etc properties.  There are multiple pages in the ANT profile so being able to do this would keep things simpler than a flat data structure.
However this is giving a runtime error on initialization of the parent class.  Example code below gives error: Could not find symbol 'child_class'
Code below shows .  What am I doing wrong?
*** EDITED - Typo in original post, but not source of problem.  Code simplified to illustrate issue ***
    class child_class
    	var x;
    	var y;
    	function initialize()
    		x=0;
    		y=0;
    class parent_class
    	var z;
    	var child;
    		z=0;
    		child = new child_class();
  • I moved it from Discussion to Bug Reports. I think that may be why it disappeared from your profile. As for the missing comments, that was human error... I inadvertently failed to check the box to migrate comments. Sorry.
  • Thank you - that is exactly it - I am creating these classes inside of a view class.  I will try the static approach.
    This post has disappeared from my profile, and all other comments have disappeared.  Do you know why?
    Best regards
    Barney
  • I'm able to reproduce this error if the above declarations are put inside of another class:
    class AClass {
        class child_class
            var x;
            var y;
                x=0;
                y=0;
        class parent_class
            var z;
            var child;
                z=0;
        var bob;
        function initialize() {
            bob = new parent_class();
    class bogusView extends WatchUi.View {
            View.initialize();
            var p = new AClass();
    I've filed a bug for this. I've also found that you can work around the problem by adding a static declarator on each of the nested class entries. I'm not certain that this won't have additional side-effects, but it does work for this trivial case.
    class AClass {
        static class child_class
        static class parent_class
