I reported this before, but it still exists and it's still extremely annoying, so I'm reporting it again.
Device: Forerunner 955 (WW)
Firmware: 27.09
Reproduction:
- Install one more data fields to the watch which make an ANT+ connection without using the new-ish "native pairing process", such as Stryd Zones and Auxiliary Heart Rate. I would link to them but it seems that Garmin doesn't want us to use the web store anymore. Do not add them to an activity yet (don't use the new setup process which prompts you to add fields to an activity.)
- Just for funsies, install a few more data fields (some of which don't make any ANT+ connections)
- Edit an activity which has no CIQ data fields
- Go to an existing data page and edit one of the fields (long press the field)
- Scroll to Connect IQ and select it
- Now try to scroll through the list (without even selecting any of the items)
- As you scroll past any of the ANT+ data fields, an intrusive full-screen prompt will pop up asking you if you want to make an open connection to [ANT+ ID]
Not only is this extremely annoying, it makes it very hard to scroll past or even select those data fields. As soon as you dismiss the prompt, it will appear again. You have to quickly dismiss the prompt and scroll away from the field.
Note that this is obviously happening because with this workflow, when you scroll to a data field, a live preview of the field is displayed. In order to do so, the CIQ data field has to run, which includes making ANT+ connections / discovering ANT+ devices.
It's funny that if you add a new data page, the initial field setup process doesn't have this problem, since it has a completely different UI (full-screen menu instead of short little popover) with no live preview.
I would suggest maybe disabling the live previews for CIQ data fields?
Or maybe this is intentional, to "encourage" CIQ devs to use the new native pairing process. Well all I can say is, Stryd, a for-profit company hasn't do so yet, and maybe never will? Not to mention all the old apps which probably won't be updated to do so.
I would bet this applies to all watches of the same-ish gen (like FR255, FR265, FR965, Fenix 7 / Fenix 7 Pro). Wouldn't be surprised if it also applies to the newer gen devices like Fenix 8.
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flocsy🤠
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
