Complete
Not a CIQ issue. For more context, here's a link to the Bug Reports FAQ, https://forums.garmin.com/developer/connect-iq/w/wiki/5/bug-reports-faq.
Next time, consider starting a discussion. A discussion can be escalated to a bug report.
Unable to test km to mile conversion of half marathon
  (:distance)
  module Distance {
    function toMiles(dist) {
      var mi = dist.toDouble() * 0.6213711922d;
      return mi.toDouble();
I have the following Test:
// t.is() == test.assertEqualmessage
// t.ok() == test.assertMessage()
// t.pass() == test.assertMessage(true, msg)
// t.fail() == test.assertMessage(false, msg)
    (:test)
    function testDistance(logger) {
      t.is(dist.toMiles(1), 0.6213711922d, "1km is 0.6213711922 miles");
      var mi = dist.toMiles(21.0975);
      Sys.println(mi); // prints 13.109379
      var mile = 13.109379d;
      Sys.println(mile); // print 13.109379
      if (mile == mi) {
        t.pass("A mile is a mile");
      else {
        t.fail("A mile isn't a mile");
      t.is(dist.toMiles(21.0975), 13.109378728d, "Half marathon distance");
      t.ok(dist.toMiles(21.0975) == 13.109379d, "Half marathon distance");
      return true;
This fails on Exception: ASSERTION FAILED: A mile isn't a mile    File: UnitTests
I'm kinda expecting it all to work.
The problem is because I cannot see what the test sees (as described here https://forums.garmin.com/developer/connect-iq/i/bug-reports/test-assertequalmessage-and-friends-to-show-incorrectness), so from there I'm sitting the values should be correct. Working around it by adding a toString() doesn't work, it still thinks it isn't the same value.
Parents
  • > allow toDouble(precision) so you can tweak the precision within the compare
    You can implement your own rounding function to do this. e.g.:
        function round(val, numDecimals) {
            val = val * Math.pow(10, numDecimals);
            val = Math.round(val);
            return val / Math.pow(10, numDecimals);
    Also, I noticed that the following code rounds to 4 places:
    System.println("miles = " + mi.format("%g"));
    So you really can't rely on the output of println() unless you ask for a lot of decimal places (like 20).
Comment
Children
No Data
