Complete
Not a CIQ issue. For more context, here's a link to the Bug Reports FAQ, https://forums.garmin.com/developer/connect-iq/w/wiki/5/bug-reports-faq.
Next time, consider starting a discussion. A discussion can be escalated to a bug report.
Unable to test km to mile conversion of half marathon
  (:distance)
  module Distance {
    function toMiles(dist) {
      var mi = dist.toDouble() * 0.6213711922d;
      return mi.toDouble();
I have the following Test:
// t.is() == test.assertEqualmessage
// t.ok() == test.assertMessage()
// t.pass() == test.assertMessage(true, msg)
// t.fail() == test.assertMessage(false, msg)
    (:test)
    function testDistance(logger) {
      t.is(dist.toMiles(1), 0.6213711922d, "1km is 0.6213711922 miles");
      var mi = dist.toMiles(21.0975);
      Sys.println(mi); // prints 13.109379
      var mile = 13.109379d;
      Sys.println(mile); // print 13.109379
      if (mile == mi) {
        t.pass("A mile is a mile");
      else {
        t.fail("A mile isn't a mile");
      t.is(dist.toMiles(21.0975), 13.109378728d, "Half marathon distance");
      t.ok(dist.toMiles(21.0975) == 13.109379d, "Half marathon distance");
      return true;
This fails on Exception: ASSERTION FAILED: A mile isn't a mile    File: UnitTests
I'm kinda expecting it all to work.
The problem is because I cannot see what the test sees (as described here https://forums.garmin.com/developer/connect-iq/i/bug-reports/test-assertequalmessage-and-friends-to-show-incorrectness), so from there I'm sitting the values should be correct. Working around it by adding a toString() doesn't work, it still thinks it isn't the same value.
Parents
  • I don't want to have to repeat all kinds of values just so I can see what is wrong. As seen in the link, I've asked to include it by the test functions. They won't because of blub reasons.
    I solved it differently tho or worked around it. In order to get assertEquals and friends to play nice, I format both the needle and the haystack with a precision of 7 digits and than compare the lot:
        function cmp_double(dbl, expect, msg) {
          dbl = dbl.format("%.7f");
          expect = expect.format("%.7f");
          // https://forums.garmin.com/developer/connect-iq/i/bug-reports/unable-to-test-km-to-mile-conversion-of-half-marathon
          //Sys.println(dbl  + " " + expect);
          t.is(dbl, expect, msg);
        (:test)
          cmp_double(dist.toMiles(1), 0.6213712d, "1km us 0.62137 miles");
          cmp_double(dist.toMiles(21.0975), 13.1093786d, "Half marathon distance");
          return true;
        (:test)
        function testWeight(logger) {
          cmp_double(mass.toLbs(1), 2.2046226d, "1kg is 2.20462 lbs");
          cmp_double(mass.toLbs(86.2), 190.0384633d, "Karting weight");
          cmp_double(mass.toLbs(20), 44.0924524d, "Barbell weight");
          return true;
    The test.assert-family should deal with the objects and how things are compared, assertEqualMessage("foo", "bar", "compare the two"); could compare with "foo".equals("bar"), but I'm not sure as Garmin has closed source their SDK.
Comment
        (:test)
          return true;
        (:test)
          return true;
Children
No Data
