(:distance)
module Distance {
function toMiles(dist) {
var mi = dist.toDouble() * 0.6213711922d;
return mi.toDouble();
I have the following Test:
// t.is() == test.assertEqualmessage
// t.ok() == test.assertMessage()
// t.pass() == test.assertMessage(true, msg)
// t.fail() == test.assertMessage(false, msg)
(:test)
function testDistance(logger) {
t.is(dist.toMiles(1), 0.6213711922d, "1km is 0.6213711922 miles");
var mi = dist.toMiles(21.0975);
Sys.println(mi); // prints 13.109379
var mile = 13.109379d;
Sys.println(mile); // print 13.109379
if (mile == mi) {
t.pass("A mile is a mile");
else {
t.fail("A mile isn't a mile");
t.is(dist.toMiles(21.0975), 13.109378728d, "Half marathon distance");
t.ok(dist.toMiles(21.0975) == 13.109379d, "Half marathon distance");
return true;
This fails on Exception: ASSERTION FAILED: A mile isn't a mile File: UnitTests
I'm kinda expecting it all to work.
The problem is because I cannot see what the test sees (as described here https://forums.garmin.com/developer/connect-iq/i/bug-reports/test-assertequalmessage-and-friends-to-show-incorrectness), so from there I'm sitting the values should be correct. Working around it by adding a toString() doesn't work, it still thinks it isn't the same value.
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
