I'm working on a Connect IQ app that processes JSON responses, which can grow quite large—sometimes approaching the size limit that triggers a -402
response code.
With these large responses, I’ve observed on my physical Epix 2 Pro that the pre-processing phase—the time between the response arriving and the onReceive
callback being invoked—can occasionally take an unusually long time. While this phase typically lasts between 150ms and 300ms, I’ve seen it spike up to 10,000ms.
The main problem with that is it blocks all other events from being processed during that time—including user input—effectively freezing the UI.
What I’d expect from the API:
If the API’s internal pre-processing of a response occasionally takes longer, I would expect it to be handled in a non-blocking way—allowing the app to remain responsive and continue handling user input.
How I measured this:
I’m not sure if this is the precise terminology, but let’s assume the CIQ engine maintains an event queue that handles user input, timer events, and web request responses.
Here's the approach: after calling makeWebRequest
, control is returned to the app, which continues processing other events. When the response arrives, it triggers a new event for processing the response and invoking onReceive
To measure the timing, I record the moment makeWebRequest
is called using System.getTimer()
. Then I schedule recurring 50ms timer events, each logging the time elapsed since the request. When onReceive
is eventually called, I measure the time again. The gap between the last timer event and the onReceive
timestamp gives an estimate of how long the pre-processing phase took after the response arrived.
This method offers a resolution of 50ms, so it’s not highly precise—but it's sufficient for spotting significant delays.
You can find the relevant code here:
https://github.com/TheNinth7/ohg/blob/onReceiveDelayTest/source/web-requests/sitemap/SitemapRequest.mc
Focus on the makeWebRequest
, onReceive
, and TimeMeasurerTask
functions. For response handling, I use a task queue whose primary purpose is to split up processing into smaller chunks—so the main thread isn't blocked for too long at once.
Test data and observations:
The test data shown below comes from two separate runs, identifiable by their timestamps. In the first run, the delay occurred as early as the third request. In the second, it took longer to reproduce, suggesting that the issue occurs sporadically.
31.5.2025 7:52:45: SitemapRequest.makeRequest: #1
31.5.2025 7:52:49: SitemapRequest.onReceive: #1
31.5.2025 7:52:49: SitemapRequest.onReceive: total=4645ms pre-processing=188ms
31.5.2025 7:52:51: SitemapRequest.makeRequest: #2
31.5.2025 7:52:51: SitemapRequest.onReceive: end
31.5.2025 7:52:52: SitemapRequest.onReceive: #2
31.5.2025 7:52:52: SitemapRequest.onReceive: total=1070ms pre-processing=148ms
31.5.2025 7:52:52: SitemapRequest.onReceive: end
31.5.2025 7:53:11: SitemapRequest.makeRequest: #3
31.5.2025 7:53:17: SitemapRequest.onReceive: #3
31.5.2025 7:53:17: SitemapRequest.onReceive: total=6643ms pre-processing=5262ms
31.5.2025 7:53:17: SitemapRequest.onReceive: end
31.5.2025 7:53:18: HomepageMenuDelegate.onBack
31.5.2025 7:56:49: SitemapRequest.makeRequest: #1
31.5.2025 7:56:50: SitemapRequest.onReceive: #1
31.5.2025 7:56:50: SitemapRequest.onReceive: total=1025ms pre-processing=171ms
31.5.2025 7:56:52: SitemapRequest.makeRequest: #2
31.5.2025 7:56:52: SitemapRequest.onReceive: end
31.5.2025 7:56:53: SitemapRequest.onReceive: #2
31.5.2025 7:56:53: SitemapRequest.onReceive: total=1080ms pre-processing=151ms
31.5.2025 7:56:53: SitemapRequest.onReceive: end
31.5.2025 7:57:2: SitemapRequest.makeRequest: #3
31.5.2025 7:57:9: SitemapRequest.onReceive: #3
31.5.2025 7:57:9: SitemapRequest.onReceive: total=7964ms pre-processing=7093ms
31.5.2025 7:57:10: SitemapRequest.onReceive: end
31.5.2025 7:57:17: SitemapRequest.makeRequest: #4
31.5.2025 7:57:19: SitemapRequest.onReceive: #4
31.5.2025 7:57:19: SitemapRequest.onReceive: total=1711ms pre-processing=302ms
31.5.2025 7:57:19: SitemapRequest.onReceive: end
31.5.2025 7:57:37: SitemapRequest.makeRequest: #5
31.5.2025 7:57:39: SitemapRequest.onReceive: #5
31.5.2025 7:57:39: SitemapRequest.onReceive: total=1960ms pre-processing=157ms
31.5.2025 7:57:39: SitemapRequest.onReceive: end
31.5.2025 7:57:58: SitemapRequest.makeRequest: #6
31.5.2025 7:58:0: SitemapRequest.onReceive: #6
31.5.2025 7:58:0: SitemapRequest.onReceive: total=1990ms pre-processing=212ms
31.5.2025 7:58:0: SitemapRequest.onReceive: end
31.5.2025 7:58:20: SitemapRequest.makeRequest: #7
31.5.2025 7:58:21: SitemapRequest.onReceive: #7
31.5.2025 7:58:21: SitemapRequest.onReceive: total=1696ms pre-processing=148ms
31.5.2025 7:58:21: SitemapRequest.onReceive: end
31.5.2025 7:58:45: SitemapRequest.makeRequest: #8
31.5.2025 7:58:48: SitemapRequest.onReceive: #8
31.5.2025 7:58:48: SitemapRequest.onReceive: total=3280ms pre-processing=1238ms
31.5.2025 7:58:48: SitemapRequest.onReceive: end
31.5.2025 7:58:49: HomepageMenuDelegate.onBack
You might also notice that the initial request sometimes takes a very long time—I’ve observed delays of up to 28 seconds. Again, this doesn’t happen consistently. Importantly, this time isn’t spent in the pre-processing phase, and it doesn’t block the user interface, so I believe it’s a separate issue. My guess is that it might be related to initializing the communication channel to the phone that's required to make the request—but that’s purely speculative at this point.
