Acknowledged
over 1 year ago
Ubuntu 24.04 support
I installed Ubuntu 24.0 and now the SDK doesn't work, the simulator... In 24.04, the webkit is version 4.1.
./sdkmanager: error while loading shared libraries: libwebkit2gtk-4.0.so.37: cannot open shared object file: No such file or directory
Parents
  • After installing your appimage i can run sdkmanager, but when launching application from vscode it does not connect to simulator, after some time it notifies that unable to connect to simulator. Also when running appimage from terminal i get warning.
    [user@host ConnectIQ]()$ sdkmanager
    Gtk-Message: 16:10:08.333: Failed to load module "xapp-gtk3-module"
    /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so: undefined symbol: g_task_set_static_name
    Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
    Gtk-Message: 16:10:24.733: Failed to load module "xapp-gtk3-module"
    ** (AppRun.wrapped:5195): WARNING **: 16:10:50.714: atk-bridge: get_device_events_reply: unknown signature
    Could this be cause of broken simulator and did you figured out how to run apps in simulator?
Comment
Children
  • Thanks @adas, yeah, it turns out both the `simulator` and `monkeymotion` binaries inside the SDKs have the same issue.  I will look at doing something similar for those, but they're a bit trickier license-wise, since those binaries are not publicly available, and instead locked behind a Garmin developer login - which is no hard to automate, but would likely run afoul of Garmin's license terms? It might be that the best I can do is provide a script that makes it easier for people to do it themselves locally, but I'm still exploring options :)
    BTW, the `libgvfscommon.so` error is benign; ie it doesn't affect the running application, as far as I can tell.
    Cheers.
