Acknowledged
CIQQA-4752
Title: Fenix 9 Pro 51mm – touch causes incorrect AOD transition with Connect IQ watch face
I am developing a Connect IQ watch face for a Fenix 9 Pro 51mm and found a problem with the transition to AOD after touching the screen.
At first I thought the problem was caused by my watch face, so I removed functionality step by step. I can reproduce the same problem with a minimal test watch face containing only a background, hour/minute hands and AOD.
The minimal test has no input delegate, no touch handling, no timers, no weather or other data APIs, and no requestUpdate calls.
Steps to reproduce:
  1. Set General Use display timeout to 15 seconds.
  2. Wake the watch face with a wrist gesture.
  3. Do not touch the screen and let it enter AOD.
  4. The AOD transition works normally.
  5. Wake the watch face again with a wrist gesture.
  6. Touch the screen once.
  7. Do nothing else and wait for AOD.
After touching the screen, the AOD screen appears but remains unusually bright and the watch face becomes temporarily unresponsive. After a while it returns to normal.
I can reproduce this with two different full Connect IQ watch face projects as well as with the minimal test project.
I then changed General Use → Display Timeout from 15 seconds to 8 seconds.
With the 8-second timeout the problem disappears. The AOD transition works normally, including after touching the screen.
I found an older Connect IQ developer discussion describing similar behavior on an Epix Gen 2. This is obviously a different device and software generation, so I don't know if the cause is related, but the observed behavior appears very similar.
I have the minimal source project that reproduces the problem and can provide it if useful.
Device: Fenix 9 Pro 51mm
Software bundle: 6.48 [DFU-017508]2161.NightRIDER_AOD_TOUCH_TEST_NO_DELEGATE.zip
