Complete
WERETECH-12153
Issue has been resolved.
The type checker warns about info[:field], even after checking :field is present.
The 4.0.7 release notes say:
 - Add type checking to ‘object[:variable]’ syntax
But now I get warnings from:
function getField(info as Object, field as Symbol) {
    if (info has field) {
        return info[field];
    return null;
WARNING: <device>: bug.mc:3: Cannot determine if container access is using container type.
Since we've checked that the field exists, there shouldn't be a need to check the container type (and it could be a class, and not a container at all).
I get the same warning using a literal symbol (obviously I could rewrite this one as info.field):
function getField(info as Object) {
    if (info has :field) {
        return info[:field];
    return null;
There doesn't seem to be a way to suppress this warning. The docs mention (:typechecker(options)), but I cant find any documentation for options - other than disableBackgroundCheck and disableGlanceCheck - and I haven't been able to guess an option that helps.
  • Thanks. (:typecheck(false)) will at least get me to a clean build.
  • Well, that is unfortunate. I believe the type checker should be able to safely deduce that obj is a MyClass and not an Array, so it should not warn.
    So, it turns out that there is an undocumented parameter that can be passed to the :typecheck annotation.. You can pass false to disable type checking for a given function entirely. Using the above snippet as an example...
    (:typecheck(false))
    function getValue(obj as MyClass, sym as Symbol) as Number or Float or Null {
        if (obj has sym) {
            return obj[sym];
        return null;
    This option was supposed to be documented. I've filed a request to get it added and to have the two blocks that discuss the :typecheck be joined into one.
  • Just to confirm, after fixing up your test case to compile:
    import Toybox.Lang;
    class MyClass
        var field1 as Number;
        var field2 as Float;
        function initialize(f1 as Number, f2 as Float) {
            field1 = f1;
            field2 = f2;
            if (obj has sym) {
                return obj[sym];
            return null;
    WARNING: <device>: bug.mc:15: Cannot determine if container access is using container type.
  • I found that page (and mentioned disableBackgroundCheck and disableGlanceCheck in my report). But if thats supposed to be a full list of currently supported options for :typecheck, the documentation could be a lot clearer.
    • those options are described in a section titled "Application Scope Type Checking", suggesting that these are the two options related to *that*, not the only two options supported.
    • the Annotations page says "Code blocks decorated with this annotation can direct the type checker to perform / avoid certain checks", implying that it can be used to both enable AND disable particular checks.
  • I originally hit this issue with “obj as Activity.Info”.
