Complete
WERETECH-11147
Fixed
The burn-in protection on Venu2(s) devices with CIQ4 falsely triggers and turns off the display
I have ported several watch faces with Venu1 AOD support to the Venu2 and Venu2s devices.
My AOD modes are straight forward. I'm using a dense pattern clearing every 2nd pixel row or column on the screen alternating each minute starting with the first row/column or the second row/column.
This ensures that less than 10% of the pixels are on and no particular pixel is on for more than 1 minute.
On the Venu2 the simulator detects a screen burn-in. On the Screen Burn-In Simulation window it looks like the overlay pattern is ignored.
Also some drawing artifacts are missing on the burn-in screen for example the minute and hour hands.
I'm in contact with 2 other developers who have similar problems with at least some of their watch faces.
I already uploaded my watch faces with Venu2 support to the Connect IQ store and received feedback from a user who also owns a Venu1 that
the AOD is not working on his new Venu2. - It turns off the screen.
So this is potentially not only a problem of the simulator but also of the actual device.
Here is a screen recording of the problem in action highlighting the differences between Venu1 and Venu2:
https://drive.google.com/file/d/123bDerdGzCovWEcJlxonKbRBSo96lqrq/view?usp=drivesdk
Parents
  • To classify something as bug you have to refer to the rules.
    If there is no more than 10% not black pixels and none of pixel is bright for more than 3 minutes it is a bug.
    There is difference between venu and venu 2 in drawing because on venu drawing black line drawing black line in venu 2 ciq add not black pixel( bluring) connected with colour of neighbour pixel. So the same code on venu can paint 10% on venu 2 15% pixels. Adding blur is also rule you have to fit to this rule.
    On video circle and system font run well and custom not. So problem can be connected with custom font that have not black/white and this can be a bug.
    In my wf, I:
    - choose the drawing that has less than 10% - 1st rule
    - move this picture in difference place to avoid 3 minutes drawing - 2nd rule
Comment
    In my wf, I:
Children
No Data
