Complete
over 4 years ago
WERETECH-11147
Fixed
The burn-in protection on Venu2(s) devices with CIQ4 falsely triggers and turns off the display
I have ported several watch faces with Venu1 AOD support to the Venu2 and Venu2s devices.
My AOD modes are straight forward. I'm using a dense pattern clearing every 2nd pixel row or column on the screen alternating each minute starting with the first row/column or the second row/column.
This ensures that less than 10% of the pixels are on and no particular pixel is on for more than 1 minute.
On the Venu2 the simulator detects a screen burn-in. On the Screen Burn-In Simulation window it looks like the overlay pattern is ignored.
Also some drawing artifacts are missing on the burn-in screen for example the minute and hour hands.
I'm in contact with 2 other developers who have similar problems with at least some of their watch faces.
I already uploaded my watch faces with Venu2 support to the Connect IQ store and received feedback from a user who also owns a Venu1 that
the AOD is not working on his new Venu2. - It turns off the screen.
So this is potentially not only a problem of the simulator but also of the actual device.
Here is a screen recording of the problem in action highlighting the differences between Venu1 and Venu2:
https://drive.google.com/file/d/123bDerdGzCovWEcJlxonKbRBSo96lqrq/view?usp=drivesdk
Parents
  • Not sure which vacuum all the replies are being sucked away to, but in answer to Jim: no.
    Dc.setColor(0,0) was pretty much my first test (referenced in my first post on the thread that predates the ticket.
    It seems that _any_ design that would break number of pixels rule in high power mode will break it in low power mode.
    It is like it counts _before_the first low power onUpdate.
Comment
Children
  • video shows that there was no interleaving pixel, heat maps says the same
    so solutions:
    1. heat map not work right and on device will be ok
    2. Pattering not work well
    rather 2, why?
    - bad algorihm
    - system draw something else if not black colour
  • That's not what I see with mine.  I have a number of WFs that run fine for the v2 in the sim.
    If the WF has say a green background with white text, that's 100% of the pixels, and it works fine in low power mode.
