Complete
WERETECH-11147
Fixed
The burn-in protection on Venu2(s) devices with CIQ4 falsely triggers and turns off the display
I have ported several watch faces with Venu1 AOD support to the Venu2 and Venu2s devices.
My AOD modes are straight forward. I'm using a dense pattern clearing every 2nd pixel row or column on the screen alternating each minute starting with the first row/column or the second row/column.
This ensures that less than 10% of the pixels are on and no particular pixel is on for more than 1 minute.
On the Venu2 the simulator detects a screen burn-in. On the Screen Burn-In Simulation window it looks like the overlay pattern is ignored.
Also some drawing artifacts are missing on the burn-in screen for example the minute and hour hands.
I'm in contact with 2 other developers who have similar problems with at least some of their watch faces.
I already uploaded my watch faces with Venu2 support to the Connect IQ store and received feedback from a user who also owns a Venu1 that
the AOD is not working on his new Venu2. - It turns off the screen.
So this is potentially not only a problem of the simulator but also of the actual device.
Here is a screen recording of the problem in action highlighting the differences between Venu1 and Venu2:
https://drive.google.com/file/d/123bDerdGzCovWEcJlxonKbRBSo96lqrq/view?usp=drivesdk
Parents
  • Hi Johnny,
    thanks for investing time in this issue!
    I figured out why the problem does not reproduce with your code. I'm using antialiasing in my watch faces whenever possible (supported and enough mem).
    I turn it on when entering onUpdate() and never turn it off. Hence the overlay pattern is also drawn with antialiasing enabled. Apart from being a waste of CPU resources it was not a problem for the burn-in protection on the Venu1.
    Here is my updated code that now works fine.
    if(ProtectAgainstBurnInWithLinePattern())
        temp_dc.setAntiAlias(false);
        temp_dc.setPenWidth(1);
        temp_dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_BLACK);
        if(VENU_AOD_HORIZONTAL_LINES == mVenuAOD)
            for(var y = mToggle ? 0 : 1; y < mDcHeight; y+=2)
                temp_dc.drawLine(0, y, mDcWidth - 1, y);
        else
            for(var x = mToggle ? 0 : 1; x < mDcWidth; x+=2)
                temp_dc.drawLine(x, 0, x, mDcHeight - 1);
Comment
  • Hi Johnny,
        else
Children
  • FYI:
    I had to do one last small correction to my code.
    Initially I had
    temp_dc.drawLine(0, y, mDcWidth, y);
    and
    temp_dc.drawLine(x, 0, x, mDcHeight);
    just like in your code. I did draw this extra pixel to make the Venu1 AOD work and I thought I can remove it since I'm now drawing without antialiasing.
    I was wrong.
    For the Venu1 and D2 Air devices I have to draw the extra pixel on the right and the bottom edge of the display. - Even with antialiasing turned off!
    Here is a modified version of your example that works on the Venu2 but triggers the Venu1 and D2 Air burn-in protection.
    No big deal but something that needs to be considered in our watch faces.
    var _cnt = 0;
    function onUpdate(dc as Dc) as Void {
        dc.clear();
        dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_BLACK);
        dc.fillRectangle(206, 0, 20, 40);
        dc.fillRectangle(206, dc.getHeight() - 40, 20, 40);
        dc.setPenWidth(1);
        var delta = _cnt%2;
        for(var x = delta; x < dc.getWidth(); x+=2) {
            dc.drawLine(x, 0, x, dc.getHeight() - 1);
        ++_cnt;
    And here is my fixed hopefully final version of the overlay pattern.
                temp_dc.drawLine(0, y, mDcWidth/* - 1*/, y); //One extra pixel on the right edge for the Venu1
        else
                temp_dc.drawLine(x, 0, x, mDcHeight/* - 1*/); //One extra pixel on the bottom edge for the Venu1
  • ah, that makes sense, thanks for letting me know.
