Complete
CIQQA-780
This is fixed in the 4.0.7 SDK and VS Code 1.0.1 extension release.
Support spaces in paths (inside VSCode)
After switching from eclipse to VSCode I found that I can't use the SIM from within the IDE anymore. After some time I found out that spaces inside my projects path are the reason for this.
Here's the issue and error I get with spaces inside my projects path: https://forums.garmin.com/developer/connect-iq/f/discussion/278947/cant-start-app-from-vscode-spaces-in-path
This is really an annoying issue for me because it forces me to change structures in my own folder structure that I do use outside of garmin iq development...
Side note:
Building and exporting works, the only issue is the installing of the prg file inside the SIM from within VSCode. I assume this is a very small issue as it should be solved by simply wrapping paths inside quotation marks when calling the script that installs the prg inside the SIM...
Parents Comment Children
No Data
