Acknowledged
String.toCharArray() crashes if the string contains Swedish characters
A user reported a crash in my data field, and I eventually narrowed it down to a line of code that was calling toCharArray() on a user-provided string.  In this case, the string was "Östra Hällsjön".
A single umlauted character is enough to cause toCharArray() to crash.  For example:
var testStr = "Ö";
var chars   = testStr.toCharArray();
In the simulator, the debug console shows:
Error: System Error
Details: Failed invoking <symbol>
Stack:
  - compute() at C:\dev
{filename}.mc:178 0x10000d9c
The line number is the line with the call to toCharArray().  I have not done extensive testing to see what other characters may cause it to crash.
SDK:  6.2.2
Devices:  Epix2 51mm, Fenix 6X, Edge 1000
Parents
  • - I'm not able to reproduce this. Here is my test app code...
    class NoBuenoView extends WatchUi.View {
        hidden var _mLines as Array<String>;
        function initialize() {
            View.initialize();
            _mLines = [] as Array<String>;
        function onShow() as Void {
            _mLines.add("Östra Hällsjön");
            _mLines.add(_mLines[0].toCharArray().toString());
        function onUpdate(dc as Dc) as Void {
            dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_WHITE);
            dc.clear();
            var cx = dc.getWidth() / 2;
            var cy = dc.getHeight() / 2;
            var font = Graphics.FONT_TINY;
            var fy = dc.getFontHeight(font);
            cy -= (fy * _mLines.size() / 2);
            for (var i = 0; i < _mLines.size(); ++i) {
                dc.drawText(cx, cy, font, _mLines[i], Graphics.TEXT_JUSTIFY_CENTER);
                cy += fy;
    Here is the result displayed on the three simulated devices on the 6.2.2 simulator. I don't read or write Swedish, but the characters look right to me. At least they look just like what appears in source displayed in vscode.
    I also tested this on physical hardware, including epix2pro51mm, fr935 (a close approximation to fenix6xpro), and edge1030 (as close as I can get to a physical edge_1000). The app didn't crash on any of the devices, and produced output consistent with what I'm seeing in the simulator.
    I also tried building with several different SDK versions back to 4.1.3 and had no issues.
Comment
            View.initialize();
            dc.clear();
                cy += fy;
Children
  • Okay.  As far as the simulator goes, if I hardcode the (Swedish) string, it works fine.  My data field is displaying the value of Activity.Info.nameOfNextPoint, which I set via the Simulation -> Set Navigation Data menu option.  When I display the same string, but grabbed from "nameOfNextPoint", the Swedish characters are not displayed properly - they show a diamond with a "?" inside.  The string displays fine on an actual device, though.  (When it is getting that value from a course that the user loads.)
    I also created a SimpleDataField to check the call to toCharArray() against a hardcoded string, and it did not crash.  It still crashes in my data field, so I have no idea why the crash is ocurring - but that call is definitely the culprit.  Removing the swedish characters from the string eliminates the crash.  I will continue to try to create a simplified project that can recreate the problem.
  • Interesting.  I'm traveling right now, but I'll create a stripped-down data field when I get back on Monday/Tuesday.  If I'm still able to recreate it, I'll share the whole project.
