Acknowledged
CIQQA-4766
Store upload reports "Signature check failed" alongside "Status: Verified" on a first upload
App: Everdo Capture (device app)
App ID: 4d358e3d5adc6de2720b297381d8b61b
Version: 1.0.0, submitted 2026-10-07
SDK: 9.2.0, packaged with `monkeyc -e -r`
On upload, the App File panel showed both of the following at once:
Status: Verified
Signature check failed.
Everything else resolved correctly: the compatible device list, version and app type were all parsed and displayed, and the listing published normally with icon, description and screenshots intact. A beta build signed with the same key installed on a Venu X1 and ran without issue.
The two documented causes do not appear to apply:
  • The signing key is 4096-bit RSA in PKCS#8 DER form, so this is not the key-length case.
  • This was the first upload under this app ID, so "all app versions have to be signed with the same key pair" cannot apply.
There is an existing acknowledged bug report describing this same message appearing spuriously. I am reporting it as an additional data point rather than a new issue.
Questions:
  1. Is this warning meaningful, or cosmetic?
  2. Will it affect my ability to publish updates to this listing signed with the same key?
Happy to supply the .iq or the public key if that helps.
