On Venu 2 devices, I'm seeing sporadic "Unhandled Exceptions" when there should be no exception.
The Properties.getValue call only has 2 published exceptions it can throw:
- (Lang.UnexpectedTypeException) —Thrown if key is a disallowed data type
- (Properties.InvalidKeyException) —Thrown if key does not exist in Application Settings
Neither of these seem applicable. The line implicated is this:
showSeconds = Properties.getValue("YShowSeconds");
Reviewing the possibilities:
- Lang.UnexpectedTypeException: The string value key is obviously an allowed type, so it's not that.
- Properties.InvalidKeyException: This property is defined correctly. It runs in the simulator on Venu 2. It runs on all other devices. This is just a sporadic failure.
Given these, I'm not sure what else I could do to resolve this.
Here is some more context:
- Right before the implicated line, there are 3 other Properties.getValue() calls made. They seem to be successful, and the properties are defined in the same file as the line that is failing.
- This call happens upon app startup.
- I don't believe this is happening on any other devices.
