Acknowledged
CIQQA-3042
Special character: sometime working, sometimes not
Since upgrading to SDK 8.1.0, I notice that sometimes the degree ° character does not work in the simulator. When restarting the simulator once or twice, it then works again.
Will add images in the comments.
  • I have the same issue using my own font for the degrees character (char id=176), sometimes I get an empty rectangle and sometimes it works. Using SDK8.1.0 and Win11. I haven't noticed that it is a specific  Product - I'll try and be more observant to see if it makes a difference which product I am simulating.
  • I'll create a new ticket for this. We have one for the issue FlowState linked to, but this seems a little different since it doesn't work and then does after restarting the sim. If it simply didn't work in the sim, I would say it's a font issue, but if it's sometimes working and sometimes not, I'm not sure what would cause that.
  • Not sure if it is the same - the issue I see only happens sometimes, most of the times the simulator displays it correctly. And the issue affects devices across the board.
  • Here an example with FR265, first with the error, and then after a restart of the simulator showing the symbol correct.
  • Across the board, for example FR265, FR265S and Fenix7S. Fonts were "RobotoRegular" or "RobotoCondensedBold" as vector fonts.
