So here is my code snippet:
using Toybox.Communications;using Toybox.WatchUi;using Toybox.Attention;function phoneAppMessageHandler(message) { var data = message.data; Communications.emptyMailbox(); if (data != null) { // Play connection tone if (Attention has :playTone) { Attention.playTone(ToneProfiles.appConnectionTone); } // Assign the server port WheelData.webServerPort = data; // And set connection state WheelData.setIsAppConnected(true); } WatchUi.requestUpdate();}This snippet is called when a new message is received from the phone(basically a callback passed to Communications.registerForPhoneAppMessages())
And for some reason it can die on Communications.emptyMailbox() with System Error exception. I have no idea what is the cause. Btw, if you are interested in source, here it is: https://github.com/Wheellog/Companion.Garmin/blob/5ee2ec80077782a5efc11841ca22a9315a3d32a1
And the thing is, that it is pretty frequent! In ERA viewer I see that it is a really popular error, with 239(!!!) occurrences!
Here is a complete report:
Error Name: System ErrorOccurrences: 239First Occurrence: 2021-06-25Last Occurrence: 2021-07-27Devices: fēnix® 6 / 6 Solar / 6 Dual Power: 16.70 fēnix® 6 Pro / 6 Sapphire / 6 Pro Solar / 6 Pro Dual Power / quatix® 6: 16.70 Forerunner® 945: 7.20 fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire / Delta Solar / Delta Solar - Ballistics Edition / quatix® 6X / 6X Solar / 6X Dual Power: 16.70 fēnix® 6S / 6S Solar / 6S Dual Power: 16.70 Descent Mk2 / Descent Mk2i: 8.20 Forerunner® 945: 7.20 Descent Mk2 / Descent Mk2i: 4.20 vívoactive® 4: 5.80 Forerunner® 245: 7.20 vívoactive® 4S: 5.80 Enduro: 16.70App Versions: 2.3.8Languages: ces, eng, fre, kor, pol, rus, spa, tha, ukrBacktrace: AppMessageHandler.phoneAppMessageHandler:7
