First a bug
1) Some namespacing/alias issue with has
using Toybox.WatchUi as Ui;
// ... code here
// eventually
if (Ui has :TextPicker) {
// do things
// Yields error:
ERROR: fenix6xpro: file:lineno: Undefined symbol ':Ui' detected.
// Needs to change to WatchUi and/or Toybox.WatchUi to not error.
Secondly a ... You may file this as a bug or a feature, because I'm torn between what it is. I just know it is a tad-bit annoying.
// Let's assume the following code:
function refresh() {
var ids = $.profiles.getIds();
for (var i =0; i< ids.size(); i++) {
var shim = $.profiles.getShim(ids[i]);
upsertProfileShim(shim);
if ($.profileDeletedId != null) {
M2.deleteItem(self, $.profileDeletedId);
// and the following code for the profile getIds() method
function getIds() as Array<String> {
var array = [] as Array<String>;
array = self.profiles.keys();
return array;
// equally frustrating, of not more
class Bar {
var thing as Array<Numeric>
function initialize() {
thing = [ 1, 2 ]; // yields and warnings
// must be changed to
thing = [ 1, 2 ] as Array<Numeric>;
// I just told you what it is
It's insanely annoying that even when we sprinkle the code in getIds() with typing information that the callers need to do the very same thing on a container. We don't have to do this for Strings or other type of objects.
class Foo {
function foo() as Foo {
return new Foo();
// This works fine, we don't need to tell anyone we are getting an object Foo.
var f = new Foo();
var b = f.foo();
var c = b.foo();
3) I came across one more thing:
Toybox.Application.Storage as st;
st.setValue("profiles", {}); // error
// Work around it
var d = { 0 => 1 };
d.remove(0);
st.setValue("profiles", d);
// Or set this piece of weirdly looking code
st.setValue("profiles", {} as Lang.Dictionary<String, Null>);
But even when you want to enforce this, please, move the warning to gradual (level 2). If you want to pedantic, be it in informative.
I want type checking 1 for checking input params at functions, but the container warnings are a bit too much.
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
