Simulator sigsegv on Communications.transmit() w/ Android companion using Connect IQ SDKs 8.4.0, 8.3.0. Works with 8.2.3. No problem with physical devices. Tried several Android SDK versions with no effect.
Also fails with samples/Comm
System is Linux using vscode
I have a lot of gdb debug data that I cannot get this site to accept.
(gdb) simulator # SDK 8.4.0 Thread 14 "TVM main" received signal SIGSEGV, Segmentation fault. [Switching to Thread 0x7fffce7fc6c0 (LWP 1384190)] 0x00005555561c6518 in ?? () Start Addr End Addr Size Offset Perms objfile 0x555555554000 0x5555557ec000 0x298000 0x0 r--p /home/xxx/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-8.4.0-2025-12-03-5122605dc/bin/simulator
(gdb) bt #0 0x00005555561c6518 in ?? () #1 0x000055555593f067 in ?? () #2 0x00005555558dd3a6 in ?? () #3 0x00005555558ddc0d in ?? () #4 0x000055555627b2b8 in ?? () #5 0x000055555612ca0c in ?? () #6 0x00005555561f9325 in ?? () #7 0x000055555627047d in ?? () #8 0x00007fffeeaa71f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442 #9 0x00007fffeeb278dc in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
