Hello,
For some reason simulator stopped working on Mac M1. It was working OK after the initial installation, then it stopped working. I managed to get it back working by completely removing and reinstalling SdkManager and everything from the ~/Library/Application Support/Garmin folder. However a shortly after that it stopped working again.
I keeps seeing these errors in the MacOS Console app:
default 16:51:48.194014+0300 runningboardd Launch request for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)> is using uid 501 (divined from auid 501 euid 501)
default 16:51:48.194072+0300 runningboardd Acquiring assertion targeting app<application.com.garmin.connectiq.simulator.6002636.6002642(501)> from originator [anon<open>(501):84500] with description <RBSAssertionDescriptor| "LS launch com.garmin.connectiq.simulator" ID:383-84500-47730 target:app<application.com.garmin.connectiq.simulator.6002636.6002642(501)> attributes:[
<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"LaunchRoleUserInteractive" sourceEnvironment:"(null)">
default 16:51:48.194133+0300 runningboardd Assertion 383-84500-47730 (target:app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>) will be created as active
default 16:51:48.194346+0300 runningboardd Executing launch request for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)> (LS launch com.garmin.connectiq.simulator)
default 16:51:48.194381+0300 runningboardd Creating and launching job for: app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>
default 16:51:48.194717+0300 runningboardd _mutateContextIfNeeded called for com.garmin.connectiq.simulator
default 16:51:48.205766+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] This process will not be managed.
default 16:51:48.205784+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] HOME is <private>
default 16:51:48.205797+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] TMPDIR is <private>
default 16:51:48.205811+0300 runningboardd Now tracking process: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.205861+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractive)
default 16:51:48.205867+0300 runningboardd Using default underlying assertion for app: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.205948+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] with description <RBSAssertionDescriptor| "RB Underlying Assertion" ID:383-383-47731 target:84504 attributes:[
<RBSDomainAttribute| domain:"com.apple.underlying" name:"defaultUnderlyingAppAssertion" sourceEnvironment:"(null)">,
<RBSAcquisitionCompletionAttribute| policy:AfterApplication>
default 16:51:48.206033+0300 runningboardd Assertion 383-383-47731 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.206219+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] reported to RB as running
default 16:51:48.206403+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.206552+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.206641+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Set darwin role to: UserInteractive
default 16:51:48.206732+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.206398+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractive)
default 16:51:48.214914+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "foregroundApp:84504" ID:383-345-47732 target:84504 attributes:[
<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"RoleUserInteractiveNonFocal" sourceEnvironment:"(null)">
default 16:51:48.215051+0300 runningboardd Assertion 383-345-47732 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.215668+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractive)
default 16:51:48.216449+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "foregroundApp:84504" ID:383-345-47733 target:84504 attributes:[
default 16:51:48.216589+0300 runningboardd Assertion 383-345-47733 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.217336+0300 runningboardd Invalidating assertion 383-345-47732 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) from originator [daemon<com.apple.coreservices.launchservicesd>:345]
default 16:51:48.217767+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "foregroundApp:84504" ID:383-345-47734 target:84504 attributes:[
default 16:51:48.217876+0300 runningboardd Assertion 383-345-47734 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.219489+0300 runningboardd Invalidating assertion 383-345-47733 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) from originator [daemon<com.apple.coreservices.launchservicesd>:345]
default 16:51:48.219897+0300 runningboardd Invalidating assertion 383-84500-47730 (target:app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>) from originator [anon<open>(501):84500]
default 16:51:48.222078+0300 runningboardd Successfully acquired underlying assertion for [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.222017+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.222131+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.222218+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.223304+0300 distnoted register name: com.apple.sharedfilelist.change object: com.apple.LSSharedFileList.ApplicationRecentDocuments/com.garmin.connectiq.simulator token: b500000073 pid: 684
default 16:51:48.267992+0300 tccd AUTHREQ_ATTRIBUTION: msgID=84504.1, attribution={requesting={<TCCDProcess: identifier=com.garmin.connectiq.simulator, pid=84504, auid=501, euid=501, binary_path=/Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app/Contents/MacOS/simulator>}, },
default 16:51:48.269484+0300 tccd AUTHREQ_SUBJECT: msgID=84504.1, subject=com.garmin.connectiq.simulator,
default 16:51:48.271693+0300 tccd AUTHREQ_ATTRIBUTION: msgID=375.551, attribution={accessing={<TCCDProcess: identifier=com.garmin.connectiq.simulator, pid=84504, auid=501, euid=501, binary_path=/Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app/Contents/MacOS/simulator>}, requesting={<TCCDProcess: identifier=com.apple.WindowServer, pid=375, auid=88, euid=88, binary_path=/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer>}, },
default 16:51:48.271771+0300 tccd requestor: <TCCDProcess: identifier=com.apple.WindowServer, pid=375, auid=88, euid=88, binary_path=/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer> is checking access for accessor <TCCDProcess: identifier=com.garmin.connectiq.simulator, pid=84504, auid=501, euid=501, binary_path=/Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app/Contents/MacOS/simulator>
default 16:51:48.273571+0300 tccd AUTHREQ_SUBJECT: msgID=375.551, subject=com.garmin.connectiq.simulator,
default 16:51:48.282448+0300 simulator CHECKIN: pid=84504
default 16:51:48.285590+0300 simulator Received configuration update from daemon (initial)
default 16:51:48.293014+0300 lockoutagent Requesting policy for bundle IDs: (
"com.garmin.connectiq.simulator"
default 16:51:48.292594+0300 launchservicesd CHECKIN:0x0-0x2d92d9 84504 com.garmin.connectiq.simulator
default 16:51:48.292805+0300 simulator CHECKEDIN: pid=84504 asn=0x0-0x2d92d9 foreground=1
default 16:51:48.294764+0300 simulator FRONTLOGGING: version 1
default 16:51:48.294812+0300 simulator Registered, pid=84504 ASN=0x0,0x2d92d9
default 16:51:48.297777+0300 simulator BringForward: pid=84504 asn=0x0-0x2d92d9 bringForward=1 foreground=1 uiElement=0 launchedByLS=1 modifiersCount=1 allDisabled=0
default 16:51:48.297966+0300 lockoutagent Requested application com.garmin.connectiq.simulator has policy OK, associated categories:DH1009 associated sites:(null) equivalent bundle identifiers:com.garmin.connectiq.simulator
default 16:51:48.297831+0300 simulator BringFrontModifier: pid=84504 asn=0x0-0x2d92d9 Modifier 0 hideAfter=0 hideOthers=0 dontMakeFrontmost=0 mouseDown=0/0 seed=0/0
default 16:51:48.297945+0300 simulator BringForward: pid=84504 asn=0x0-0x2d92d9
default 16:51:48.297981+0300 simulator SetFrontProcess: asn=0x0-0x2d92d9 options=0
default 16:51:48.299276+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "frontmost:84504" ID:383-345-47735 target:84504 attributes:[
<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"RoleUserInteractiveFocal" sourceEnvironment:"(null)">
default 16:51:48.299395+0300 runningboardd Assertion 383-345-47735 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.302135+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.WindowServer(88)>:375] with description <RBSAssertionDescriptor| "FUSBFrontmostProcess" ID:383-375-47736 target:84504 attributes:[
<RBSDomainAttribute| domain:"com.apple.fuseboard" name:"Frontmost" sourceEnvironment:"(null)">,
default 16:51:48.302252+0300 runningboardd Assertion 383-375-47736 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.302643+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.302664+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.302684+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Set darwin role to: UserInteractiveFocal
default 16:51:48.302696+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.302689+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractiveFocal)
default 16:51:48.302978+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractiveFocal)
default 16:51:48.303284+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.303353+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.303462+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.304445+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [daemon<com.apple.coreservices.launchservicesd>:345] with description <RBSAssertionDescriptor| "notification:84504" ID:383-345-47737 target:84504 attributes:[
<RBSDomainAttribute| domain:"com.apple.launchservicesd" name:"LSNotification" sourceEnvironment:"(null)">
default 16:51:48.304490+0300 runningboardd Assertion 383-345-47737 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.304964+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractiveFocal)
default 16:51:48.304986+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.306804+0300 simulator Current system appearance, (HLTB: 1), (SLS: 0)
default 16:51:48.305030+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.310761+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.310766+0300 simulator No persisted cache on this platform.
default 16:51:48.311922+0300 simulator Failed to copy the SysCfgDict MG key with error: 0
default 16:51:48.313549+0300 simulator Post-registration system appearance: (HLTB: 1)
default 16:51:48.350050+0300 distnoted register name: com.apple.xctest.FakeForceTouchDevice object: com.garmin.connectiq.simulator token: 1e00000021 pid: 84504
default 16:51:48.354314+0300 simulator Registering for test daemon availability notify post.
default 16:51:48.354454+0300 simulator notify_get_state check indicated test daemon not ready.
default 16:51:48.354562+0300 simulator notify_get_state check indicated test daemon not ready.
default 16:51:48.354674+0300 simulator notify_get_state check indicated test daemon not ready.
default 16:51:48.359370+0300 simulator SignalReady: pid=84504 asn=0x0-0x2d92d9
default 16:51:48.360080+0300 simulator SIGNAL: pid=84504 asn=0x0x-0x2d92d9
default 16:51:48.362039+0300 simulator Initializing connection
default 16:51:48.362097+0300 simulator Removing all cached process handles
default 16:51:48.362232+0300 simulator Sending handshake request attempt #1 to server
default 16:51:48.362255+0300 simulator Creating connection to com.apple.runningboard
default 16:51:48.362720+0300 runningboardd Setting client for [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] as ready
default 16:51:48.363065+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.363044+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractiveFocal)
default 16:51:48.363595+0300 simulator Handshake succeeded
default 16:51:48.363626+0300 simulator Identity resolved as app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>
default 16:51:48.363491+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.363547+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.363899+0300 runningboardd Acquiring assertion targeting [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] from originator [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] with description <RBSAssertionDescriptor| "AppNap adapter assertion" ID:383-84504-47738 target:84504 attributes:[
<RBSAcquisitionCompletionAttribute| policy:AfterApplication>,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"Enable" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"Inactive" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"PreventDiskThrottle" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"PreventSuppressedCPU" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"PreventLowPriorirtyCPU" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"PreventBackgroundSockets" sourceEnvironment:"(null)">,
<RBSDomainAttribute| domain:"com.apple.appnap" name:"PreventTimerThrottleTier0"<…>
default 16:51:48.363995+0300 runningboardd Assertion 383-84504-47738 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) will be created as active
default 16:51:48.364408+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring jetsam update because this process is not memory-managed
default 16:51:48.364424+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring suspend because this process is not lifecycle managed
default 16:51:48.364447+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Ignoring GPU update because this process is not GPU managed
default 16:51:48.364518+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] Set AppNap state: <RBMutableProcessAppNapState|0x132b529c0 enabled:Y active:N socket:N disk:N priority:N cpu:N timer:Tier0>
default 16:51:48.364804+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: running-active (role: UserInteractiveFocal)
default 16:51:48.368268+0300 tccd -[TCCDAccessIdentity staticCode]: static code for: identifier com.garmin.connectiq.simulator, type: 0: 0x124642670 at /Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app
default 16:51:48.375027+0300 distnoted register name: com.apple.nsquiet_safe_quit_give_reason object: com.garmin.connectiq.simulator token: 3b0000003b pid: 84504
error 16:51:48.387213+0300 tccd Prompting policy for hardened runtime; service: kTCCServiceAppleEvents requires entitlement com.apple.security.automation.apple-events but it is missing for accessing={<TCCDProcess: identifier=com.garmin.connectiq.simulator, pid=84504, auid=501, euid=501, binary_path=/Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app/Contents/MacOS/simulator>}, requesting={<TCCDProcess: identifier=com.apple.appleeventsd, pid=523, auid=55, euid=55, binary_path=/System/Library/CoreServices/appleeventsd>},
default 16:51:48.389481+0300 simulator Entering exit handler.
default 16:51:48.389508+0300 simulator Exiting exit handler.
default 16:51:48.403919+0300 runningboardd XPC connection invalidated: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.404422+0300 runningboardd Invalidating assertion 383-345-47735 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) from originator [daemon<com.apple.coreservices.launchservicesd>:345]
default 16:51:48.404484+0300 runningboardd Invalidating assertion 383-345-47737 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) from originator [daemon<com.apple.coreservices.launchservicesd>:345]
default 16:51:48.410329+0300 runningboardd Invalidating assertion 383-375-47736 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]) from originator [daemon<com.apple.WindowServer(88)>:375]
default 16:51:48.411495+0300 runningboardd [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504] termination reported by launchd (0, 0, 65280)
default 16:51:48.411741+0300 runningboardd Removing process: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.411870+0300 runningboardd Removing launch job for: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.412101+0300 runningboardd Removed job for [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.412113+0300 runningboardd Removing assertions for terminated process: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
default 16:51:48.412142+0300 runningboardd Removed last relative-start-date-defining assertion for process app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>
default 16:51:48.431463+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: none (role: None)
default 16:51:48.431732+0300 runningboardd Calculated state for app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>: none (role: None)
default 16:51:48.432269+0300 launchservicesd Hit the server for a process handle 96f38d00014a18 that resolved to: [app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504]
error 16:51:48.492456+0300 kernel Sandbox: gamed(4587) deny(1) file-read-data /Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/ConnectIQ.app
error 16:51:48.541960+0300 runningboardd RBSStateCapture remove item called for untracked item 383-345-47737 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504])
error 16:51:48.542023+0300 runningboardd RBSStateCapture remove item called for untracked item 383-375-47736 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504])
error 16:51:48.542064+0300 runningboardd RBSStateCapture remove item called for untracked item 383-345-47735 (target:[app<application.com.garmin.connectiq.simulator.6002636.6002642(501)>:84504])
Brandon.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
Brandon.ConnectIQ
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
