Acknowledged
CIQQA-3803
Simulator does not load the PGS position from the ini file
Hi I am working on an app where I need the current position Position.getInfo().location
When the simulator is launched for testing it responds with an illegal Position.Location.
When I enter a valid GPS position in the menu item in the simulator it works (sometimes). I have verified the valid position is saved in simulator.ini.
But it is not loaded, which is extremely annoying during testing.
Please fix this.
Thank you.
Parents
  • Understand that on a real device, this can be null, based on when GPS was last used.
    I tend to use Actiivity.getActivityInfo().currentLocation, and after maybe an hour, it returns null, or if GPS hasn't been used since the device was turned on.
    If you see a good location, save that to storage, and then use the value from storage if the current value is null
Comment
Children
No Data
