Acknowledged
CIQQA-3217
Simulator does not apply updated property values without "Reset All App Data"
In the Connect IQ simulator (SDK 8.1.1), changes to <property> values are not reflected unless Reset All App Data is performed.
Steps to Reproduce:
  1. Define properties, for example::
    <resources>
        <properties>
            <property id="menuTitleBackgroundColor" type="number">0x212021</property>
            <property id="menuItemLeftPaddingFactor" type="float">0.03</property>
        </properties>
    </resources>
  2. Launch the app in the simulator and close the simulator again.
  3. Modify one of the <property> values in the XML file.
  4. Relaunch the app in the simulator (without resetting app data).
Expected Result:
The updated property values should be reflected when the app is reloaded.
Actual Result:
The simulator continues to use the old property values until Reset All App Data is performed.
Additional Notes:
  • If different values are specified for individual devices, switching between devices does not trigger a property refresh. The simulator continues using the values from the first device launched after the last reset.
  • This issue makes it difficult to test dynamic UI changes based on property updates.
SDK Version: 8.1.1
Parents Comment Children
No Data
