In the Connect IQ simulator (SDK 8.1.1), changes to <property> values are not reflected unless Reset All App Data is performed.
Steps to Reproduce:
Define properties, for example::
<resources> <properties> <property id="menuTitleBackgroundColor" type="number">0x212021</property> <property id="menuItemLeftPaddingFactor" type="float">0.03</property> </properties> </resources> -
Launch the app in the simulator and close the simulator again.
Modify one of the
<property>values in the XML file. -
Relaunch the app in the simulator (without resetting app data).
Expected Result:
The updated property values should be reflected when the app is reloaded.
Actual Result:
The simulator continues to use the old property values until Reset All App Data is performed.
Additional Notes:
If different values are specified for individual devices, switching between devices does not trigger a property refresh. The simulator continues using the values from the first device launched after the last reset.
This issue makes it difficult to test dynamic UI changes based on property updates.
SDK Version: 8.1.1
the-ninth
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
the-ninth
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
