Ticket Created
WERETECH-12507
Simulator Bug in latest SDK 4.1.2
I installed SDK 4.1.2, and there seems to be a couple bugs in the Simulator. They both related to App settings:
  • When you open the app settings (I ran a watch face app in simulator), and click Save, the Save button stays grayed out. You have to close the settins window and re-open it to be able to save again.
  • Some Boolean properties do not get saved. Specifically, if a property was TRUE by default, disabling it doesn't change it. App still sees TRUE, and when you re-open settings, the property is indeed TRUE again. This might not apply to ALL properties, but I definetly have a few that do that. If I change the default to FALSE, it works as expected.
, would you plese submit a bug?
Thanks
Parents
  • for the 1st one: I agree with you this sounds like a bug in sim, though it (unfortunately) kind of works similar to Garmin Connect Mobile app, where save button also closes the settings page. Probably there was a bug they couldn't solve and decided to do this "workaround". Maybe they have some similar issues in the sim as well and they just forgot to add the "close window". Though if Garmin reads this, then it would really be better if the settings window could be kept open and we could change the settings, then hit save, see the changes in the watch, then change again, etc... This is true both in sim and GCM app.
Comment
Children
No Data
