Acknowledged
Simulator Bug: Clears Memory after Sending Settings
Simulator Clears device memory after sending settings. This has never happened in the past, has anyone else experienced this?
Parents
  • That may not be "plenty" based on what you are doing with settings, as changing settings requires a bunch of memory - the app has to merge the old with the new and can be in the 2+kb range,   What do you see as the current memory usage (check "view memory" vs the bottom line of the sim).
    The problem you describe is what you can see when there's not enough memory to update the settings.
Comment
Children
