Ticket Created
WERETECH-8118
Sim issue with saveWaypoints
In the sim using 3.1.5, the following sometimes doesn't work.
Toybox.PersistedContent.saveWaypoint(location, {:name => name});
It works fine in the device (a real 1030).
  • It looks like saveWaypoint() always adds the waypoint, creating a new name if the name is already used.
    saveWaypoint() should return the new waypoint with the updated name.
  • That's what I do in the code (I provide an option to exist as an intent).
    function getLocation(name)
    if(appbase.hasStorage)
    if (PersistedContent has :getWaypoints)
    name = name.substring(0, iNameLength);
    var cit = PersistedContent.getWaypoints();
    while (cit != null)
    var waypoint = cit.next();
    if (waypoint == null)
    break;
    if(waypoint.getName().equals(name))
    return waypoint;
    return null;
  • If it was saving, you'd be able to find it in the waypoints collection. It doesn't find it in the sim (but does in the real device).
  • Both. It's a different coordinates and in another place in the code.
    function addLocation(itemLocation)
    var name = itemLocation["name"];
    var lat = itemLocation["lat"];
    var lon = itemLocation["lon"];
    try
    System.println("Downloaded location: "+name.toString()+" "+lat.toString()+","+lon.toString());
    var location = new Position.Location({:latitude => lat.toFloat(), :longitude => lon.toFloat(), :format => :degrees});
    var track = getCurrentTrack(false);
    if (track != null && track instanceof TrackObj)
    if(track.isource.equals(:frompluscode) || track.isource.equals(:fromsendpoints))
    name = "+ "+name;
    if (Toybox has :PersistedContent)
    courseLoadedLast = getLocation(name);
    itypeLoadedLast = :type_loc;
    var bEncode = false;
    if(track.isource.equals(:frompluscode))
    track.details = "Plus Code location";
    else if(track.isource.equals(:fromsendpoints))
    track.details = "Sendpoints location";
    bEncode = true;
    track.file_type = :type_waypoint;
    track.title = name;
    track.coursename = name;
    track.lat = lat;
    track.lon = lon;
    track.details += " "+track.title + ".";
    if(bEncode)
    track.details += " "+OLCObj.encodeOLC(lat.toFloat(), lon.toFloat());
    track.distanceFrom(appbase.latCurrent, appbase.lonCurrent, unitsDistance);
    if(track.web.equals(""))
    track.web = ""%.8f")+","+track.lon.toDouble().format("%.8f");">maps.google.com
    addCourse(track);
    catch (ex)
    System.println(ex.getErrorMessage());
    appbase.strStatus = "Download "+name+" failed";
  • This is what I have at this point to test that the Waypoints are being sucessfully saved. Is this a valid case to cover the bug we are discussing?
    To make this easier I clear %TEMP%/Garmin so I always see only the 1 waypoint.
                var location = new Position.Location({:latitude => 39.737306, :longitude => -104.990852, :format => :degrees});
                System.println("Hit A");
                PersistedContent.saveWaypoint(location, {:name => "Denver"});
                var wpIterator = PersistedContent.getWaypoints();
                System.println("");
                var wp = wpIterator.next();
                while (wp != null) {
                    System.println(wp.getId());
                    System.println(wp.getName());
                    wp.remove();
